Hi guys.
I was recently restructuring the minimal branch of the git repository and I decided to change the paradigm a bit. I restructured the minimal branch to a branch that allows you to create minimal versions of the SimpleFOClibrary specific for everyone’s needs.
This feature will enable you to:
- Have smaller code size
- Compile only the parts of the library you will be using in your code
- Have more than one version of the library on your system
- Dig into the library source code much easier
- Customization
- Implementation of new features/microcontrollers
How to create your own minimal version of the SimpleFOClibrary project
Creating your own minimal project version is very simple and is done in four steps:
- Step 0: Download minimal branch contents to your PC
- Step 1: Create your the arduino project
- Step 2: Add motor specific code
- Step 3: Add sensor specific code
Step 0. Download the code
Github website download
- Make sure you are in minimal branch
- Download the code by clicking on the
Clone or Download > Download ZIP. - Unzip it
Using terminal
- Open the terminal:
cd *to you desired directory* git clone -b minimal https://github.com/simplefoc/Arduino-FOC.git
Step 1. Creating the Arduino project
Open a directory you want to use as your arduino project directory my_arduino_project and create my_arduino_project.ino file. After this you create src folder in this directory and copy the folder named common from the library_source folder. Your project directory should now have structure:
├─── my_arduino_project
| ├─ my_arduino_project.ino
| └─── src
| | ├─── common # Contains all the common utility classes and functions
| | ├─ defaults.h # default motion control parameters
| | ├─ foc_utils.cpp./h # utility functions of the FOC algorithm
| | ├─ hardware_utils.cpp./h # all the hardware specific implementations are in these files
| | ├─ pid.cpp./h # class implementing PID controller
| | ├─ lowpass_filter.cpp./h # class implementing Low pass filter
| | ├─ FOCMotor.cpp./h # common class for all implemented motors
| | └─ Sensor./h # common class for all implemented sensors
Step 2. Add motor specific code
If you wish to use the BLDC motor with your setup you will have to copy the BLDCMotor.cpp/h from the library_source folder, and if you wish to use the stepper motor make sure to copy the StepperMotor.cpp/h files and place them to the src folder
| └─── src
| | ├─── common # Common utility classes and functions
| | └─ BLDCMotor.cpp/h # BLDC motor handling class
And in your Arduino code in the my_arduino_project.ino file make sure to add the the include:
#include "src/BLDCMotor.h"
For stepper motors the procedure is equivalent:
| └─── src
| | └─ StepperMotor.cpp/h # Stepper motor handling class
And the include:
#include "src/StepperMotor.h"
If you wish to run your motor in the open loop mode these are all the files that you will need. See the arduino_foc_bldc_openloop and arduino_foc_stepper_openloop project example.
Step 3. Add sensor specific code
In order to support the different position sensors you will have to copy their *.cpp and *.h into your src directory. All you need to do is copy the header files from the library_source directory.
Example: Encoder sensor
For example if you wish to use BLDC motor and encoder as a sensor, your arduino project will have structure:
| └─── src
| | ├─ BLDCMotor.cpp/h # BLDC motor handling class
| | └─ Encoder.cpp/h # Encoder class implementing the Quadrature encoder operations
And your includes will be:
#include "src/Encoder.h"
See arduino_foc_bldc_encoder project example or arduino_foc_stepper_encoder for stepper equivalent.
Example: SPI Magnetic sensor
If you wish to use Stepper motor and SPI magnetic sensor in your project, your folder structure will be:
| └─── src
| | ├─ StepperMotor.cpp/h # Stepper motor handling class
| | └─ MagneticSensorSPI.cpp/h # class implementing SPI communication for Magnetic sensors
#include "src/MagneticSensorSPI.h"
See arduino_foc_stepper_magnetic_spi project example or arduino_foc_bldc_magnetic_spi for BLDC motor equivalent.
Example: Multiple sensors: analog magnetic sensor and encoder
For example if you wish to use magnetic sensor with SPI communication, your arduino project will have structure:
| └─── src
| | ├─ Encoder.cpp/h # Encoder class implementing the Quadrature encoder operations
| | └─ MagneticSensorAnalog.cpp/h # class implementing Analog output for Magnetic sensors
#include "src/MagneticSensorAnalog.h"
Let me know what do you think.
