SimpleFOC sensorless fan for dealing with this summer's heat waves
Hi guys,
We the recent heatwaves one can be stuck at home with no air conditioning and no fan.
For those having a BLDC motor and a drone prop, SimpleFOC can provide a solution :smiley:
#include "current_sense/hardware_specific/stm32/stm32_mcu.h"
#include <encoders/MXLEMMING_observer/MXLEMMINGObserverSensor.h>
BLDCMotor motor = BLDCMotor(11, 0.29, 380.0f, 0.00009f, 0.00006f); // sunnysky
BLDCDriver3PWM driver = BLDCDriver3PWM(D6, D10, D5, D8);
// INA240-A1 + a parallel of 4mOhm resistors
LowsideCurrentSense current_sense = LowsideCurrentSense(0.002, 20.0f, A1, _NC, A2);
// sensorless observer
MXLEMMINGObserverSensor sensor = MXLEMMINGObserverSensor(motor);
void doMotor(char* cmd){ command.motor(&motor, cmd); }
// STEMMA interface for potentiometer and the screen
#include "Adafruit_seesaw.h"
#include <Adafruit_SSD1306.h>
#define SCREEN_WIDTH 128 // OLED display width, in pixels
#define SCREEN_HEIGHT 64 // OLED display height, in pixels
#define OLED_RESET     -1 // Reset pin # (or -1 if sharing Arduino reset pin)
#define SCREEN_ADDRESS 0x3D ///< See datasheet for Address; 0x3D for 128x64, 0x3C for 128x32
#define  DEFAULT_I2C_ADDR 0x30
#define  ANALOGIN   18
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, OLED_RESET);
Adafruit_seesaw seesaw(&Wire);
void printToDisplay(const String &line1, const String &line2 = "") {
  display.clearDisplay();
  display.setTextSize(1);      // Normal 1:1 pixel scale
  display.setTextColor(SSD1306_WHITE); // Draw white text
  display.setCursor(0,0);     // Start at top-left corner
  display.println(line1);
  display.println(line2);
  display.display();
  // connect the STEMMA interface
  while (!seesaw.begin(DEFAULT_I2C_ADDR, -1, false)) {
    Serial.println(F("seesaw not found!"));
    delay(1);
  // SSD1306_SWITCHCAPVCC = generate display voltage from 3.3V internally
  if(!display.begin(SSD1306_SWITCHCAPVCC, SCREEN_ADDRESS,false, false)) {
    Serial.println(F("SSD1306 allocation failed"));
    for(;;); // Don't proceed, loop forever
  // Show initial display buffer contents on the screen --
  // the library initializes this with an Adafruit splash screen.
  display.display();
  // Clear the buffer
  // link driver
  motor.PID_velocity.P = 0.05f;
  motor.PID_velocity.I = 1;
  motor.voltage_limit = 12;
  // angle loop controller
  motor.P_angle.P = 20;
  // angle loop velocity limit
  motor.velocity_limit = 20;
  motor.monitor_downsample = 0; // disable intially
  motor.monitor_variables = _MON_TARGET | _MON_VEL | _MON_ANGLE; // monitor target velocity and angle
  current_sense.init();
  motor.voltage_limit = 6;
  motor.sensor_direction= Direction::CW;
  motor.zero_electric_angle = 0;
  // initialise motor
  motor.tuneCurrentController(100.0);
  motor.target = 0;
  //command.add('T', doMotion, "motion control");
  // create a hardware timer
  // For example, we will create a timer that runs at 10kHz on the TIM5
  HardwareTimer* timer = new HardwareTimer(TIM8);
  // Set timer frequency to 20kHz
  timer->setOverflow(20000, HERTZ_FORMAT);
  // add the loopFOC and move to the timer
  timer->attachInterrupt([](){
    // call the loopFOC and move functions
  // start the timer
  timer->resume();
int t = 0;
uint32_t last_loop_timestamp_us = 0;
  // // read the potentiometer
  uint16_t slide_val = seesaw.analogRead(ANALOGIN);
  //Serial.println(slide_val);
  printToDisplay("Slide Potentiometer", "Value: " + String(slide_val/1023.0f * 100.0f, 2) + "%");
  motor.target = (slide_val / 1023.0f) * 1.5f; // set target velocity based on potentiometer value
Here are some photos:
The hardware is:
  • SimpleFOC Drive shield
  • Stemma potentiometer + a screen
  • stm32h7 nucleo board (can be any other nucleo here)
  • Random sunnysky motor X4108S
  • Some random drone propeller
I’m very happy with it actually. It’s working more or less continuously for at least 4-5h each one of the last couple of days. Of course the noise makes it more similar to an airplane taking off than a room fan, but still. :smiley:
Someone motivated to make an enclosure and make the SimpleFOCFan™ :dashing_away: :rofl:
6
Love it! I’ve always had to painstakingly tune the sensorless parameters by hand, so if this is able to run with fully automatic calibration, that’s a huge improvement.
Hey @dekutree64,
The only parameter that I needed to set by hand is the KV rating.
The resistance and the inductance were measured using the motor.characteriseMotor().
I mean in this code I’ve hard-coded them because I dont want to measure them every single time, but you could in theory.
Then the current PID values are autotuned with the bandwidth and the motor parameters. This works very very well!
I have connected a 12V PC fan to the outlet of my 5kW diesel heater. The heater is in the cold cellar and of course it is off now. The PC fan can still suck cool air in the bedroom, where I need it the most. It’s super silent, too.
I wished, I could hack the fan of the diesel heater to work standalone, but it is temp controlled.
Please do not heatstroke Antun! Thank you!
Hi @Antun_Skuric, can you please elaborate on this?
https://docs.simplefoc.com/tuning_current_loop#automatic-current-pi-tuning
Bit overkill for SimpleFOC! I think you should add a 0.1 degree accurate hall effect sensor to ensure the propeller is in exactly the right place while rotating. :wink:
