I have built a balancing robot based on the simple FOC balancer example. I am using an esp32, gimbal motors, AS5600 encoders, simpleFOC mini drivers and an MPU6050. I am at the point where I am tuning the PID parameters. I am doing this manually by updating the code but off coarse this is very tedious. Could someone clarify the use of the commander functions in this example of the code. Using a ? I see the A-E commands. I need clarification of the format of the command line used at the serial terminal to change each parameter. Thank you in advance. Glenn
