Serial Communication Problem
I am trying to use my Arduino as an EtherCAT Slave to control a motor. I use the EasyCAT Shield to connect my Arduino with the PLC.
My problem:
I have already tried to send measurements from a gyroscope to the PLC and everything works just fine. Now I am trying to send measurements form my encoders (SPI to Arduino) to the PLC run them through a controller and send the target value back to the Arduino. If I am using the following code, the Arduino will randomly stop working (sometimes after a few seconds, sometimes it takes longer).
// include header
#include <math.h>
#include <MegunoLink.h>
#include "Filter.h"
// ---------- EasyCAT declaration -----------------------------
// include header for EasyCAT configuration
#include <EasyCAT_Pendulum_config.h>
// set to Custom mode
#define CUSTOM
// include EasyCAT header to interface the LAN9252
#include <EasyCAT.h>
// EasyCAT istantiation with SPI chip select pin 7
EasyCAT EASYCAT(7);
// ---------- Simple FOC declaration --------------------------
// BLDC motor init
// driver instance
// Motor encoder init
MagneticSensorSPI encoder = MagneticSensorSPI(12, 14);
// pendulum encoder init
MagneticSensorSPI pendulum = MagneticSensorSPI(11, 14);
float pendulumoffset = 0;
// ---------- Filter declaration ------------------------------
ExponentialFilter<long>PendulumVelocityFilter(10,0);
ExponentialFilter<long>MotorShaftVelocityFilter(10,0);
  Serial.begin(9600);
  // initialise motor encoder hardware
  encoder.init();
  // init the pendulum encoder
  pendulum.init();
  pendulum.update();
  pendulumoffset = pendulum.getAngle();
  // link the motor to the encoder
  motor.linkSensor(&encoder);
  // driver
  // link the driver and the motor
   // limiting motor movements
  motor.phase_resistance = 11.1; // [Ohm]
  motor.current_limit = 1.5;   // [Amps] - if phase resistance defined
  motor.voltage_limit = 20;   // [Volts]
  motor.motion_cnt = 0;
  // setup EasyCAT
  setup_EasyCAT();
// loop downsampling counter
long loop_count = 0;
float targetVoltage;
float anglesend=0;
float pendulumVelsend=0;
float motorVelsend=0;
  // ~1ms
  // Simple FOC main task
  // EasyCAT main task
  EASYCAT.MainTask();
  // control loop each ~25ms
  if(loop_count++ > 25){
    //EASYCAT.MainTask();
    // updating the pendulum angle sensor
    // NECESSARY for library versions > v2.2
    pendulum.update();
    encoder.update();
    // calculate the pendulum angle
    float pendulumAngle = constrainAngle((pendulum.getAngle()-pendulumoffset) + PI);
    // filter the measurements
    PendulumVelocityFilter.Filter(pendulum.getVelocity());
    MotorShaftVelocityFilter.Filter(motor.shaftVelocity());
    anglesend=pendulumAngle;
pendulumVelsend=PendulumVelocityFilter.Current();
motorVelsend=MotorShaftVelocityFilter.Current();
    // send new measurements to EtherCAT Master
    EASYCAT.BufferIn.Cust.PendulumAngle = anglesend;
    EASYCAT.BufferIn.Cust.PendulumVelocity = pendulumVelsend;
    EASYCAT.BufferIn.Cust.MotorShaftVelocity = motorVelsend;
loop_count=0;
  if (targetVoltage != EASYCAT.BufferOut.Cust.MotorVoltage){
    //  get new values from EtherCAT Master
    targetVoltage = EASYCAT.BufferOut.Cust.MotorVoltage;
    // set the target voltage to the motor
    motor.move(targetVoltage);
// function constraining the angle in between -pi and pi, in degrees -180 and 180
float constrainAngle(float x){
    x = fmod(x + PI, _2PI);
    if (x < 0)
        x += _2PI;
    return x - PI;
void setup_EasyCAT()
	// print the banner
	Serial.print ("\nEasyCAT - Generic EtherCAT slave\n");
	//---- initialize the EasyCAT board -----
	// initialization
	if (EASYCAT.Init() == true)
		// succesfully completed
		Serial.print ("initialized");
	else
		// initialization failed
		// the EasyCAT board was not recognized
		Serial.print ("initialization failed");
		// The most common reason is that the SPI
		// chip select choosen on the board doesn't
}// setup_EasyCAT()
I have also tried to create a new test project. In this project I send the same measurements to the PLC and send the target value back.
I started with nothing but the sending the values and everything works fine.
In the next step included the SimpleFOC.h and implemented the closed loop test project. As soon as the the SimpleFOC is included the same thing as before happens the Arduino just stops working randomly.
#include "EasyCAT_Pendulum_config.h"
#define CUSTOM
#include "EasyCAT.h"
EasyCAT EASYCAT(7);
// encoder instance
  Serial.begin(9600);
  encoder.init();
  // link driver
  // add current limit
  //motor.motion_cnt = 0;
  setup_EasyCAT();
float targetVoltage=0;
int loopcount=0;
float toTwin1=0;
float toTwin2=100;
float toTwin3=200;
  EASYCAT.MainTask();
  if(loopcount++>25){
    EASYCAT.BufferIn.Cust.PendulumAngle = toTwin1++;
    EASYCAT.BufferIn.Cust.PendulumVelocity = toTwin2++;
    EASYCAT.BufferIn.Cust.MotorShaftVelocity = toTwin3++;
    loopcount=0;
  // print the banner
  // initialization
  else
}// setup_EasyCAT()
I have tried to change the baudrate but couldn’t find a setting which worked.
Does the simpleFOC interfere with the Serial communication?
Has anybody an idea what I can try to solve this problem?
I don’t think so, except that it prints stuff sometimes. Never had any problems with that.
That is slower than a modem from 1996!
Can you get both sides to agree on something a little faster? A common value is 115200 (12x) but I often push this to 921600 (96x).
A slow Serial (or too much printing) is the cause of much weird behaviour.
