Hi.
Today, the missing element finally arrived and I was able to return to the robot. I adjusted the Arduino-FOC-balancer code to fit my needs. Unfortunately, the robot, as shown in the video, did not work well. Maybe you have suggestions on what’s not working properly
#include "imu_helpers.h"
#include "BluetoothSerial.h"
BluetoothSerial bluetooth;
BLDCMotor motor1 = BLDCMotor(7);
BLDCDriver3PWM driver1 = BLDCDriver3PWM(32, 33, 25, 22);
MagneticSensorSPI encoder1 = MagneticSensorSPI(AS5147_SPI, 15); //- R
BLDCMotor motor2 = BLDCMotor(7);
BLDCDriver3PWM driver2 = BLDCDriver3PWM(26, 27, 14, 12);
MagneticSensorSPI encoder2 = MagneticSensorSPI(AS5147_SPI, 5); // - L
PIDController pid_stb{.P = 30, .I = 100, .D = 1, .ramp = 100000, .limit = 7};
PIDController pid_vel{.P = 0.01, .I = 0.03, .D = 0, .ramp = 10000, .limit = _PI / 10};
LowPassFilter lpf_pitch_cmd{.Tf = 0.07};
LowPassFilter lpf_throttle{.Tf = 0.5};
LowPassFilter lpf_steering{.Tf = 0.1};
float steering = 0;
float throttle = 0;
float max_throttle = 10; // 20 rad/s
float max_steering = 1; // 1 V
int state = 1; // 1 on / 0 off
void cntStab(char *cmd) { commander.pid(&pid_stb, cmd); }
void cntMove(char *cmd) { commander.pid(&pid_vel, cmd); }
void lpfPitch(char *cmd) { commander.lpf(&lpf_pitch_cmd, cmd); }
void lpfSteering(char *cmd) { commander.lpf(&lpf_steering, cmd); }
void lpfThrottle(char *cmd) { commander.lpf(&lpf_throttle, cmd); }
void setup()
Serial.begin(250000);
if (!initIMU())
Serial.println(F("IMU connection problem... Disabling!"));
return;
encoder1.init();
encoder2.init();
motor1.linkSensor(&encoder1);
motor2.linkSensor(&encoder2);
driver1.voltage_power_supply = 4;
driver1.init();
motor1.linkDriver(&driver1);
driver2.voltage_power_supply = 4;
driver2.init();
motor2.linkDriver(&driver2);
motor1.controller = MotionControlType::torque;
motor2.controller = MotionControlType::torque;
motor1.useMonitoring(Serial);
motor2.useMonitoring(Serial);
motor1.init();
motor2.init();
motor1.initFOC();
motor2.initFOC();
commander.add('A', cntStab, "pid stab");
commander.add('B', cntMove, "pid vel");
commander.add('C', lpfThrottle, "lpf vel command");
commander.add('D', lpfPitch, "lpf throttle");
commander.add('E', lpfSteering, "lpf steering");
Serial.println(F("Balancing robot ready!"));
void loop()
motor1.loopFOC();
motor2.loopFOC();
motor1.move();
motor2.move();
if (!state)
motor1.target = 0;
motor2.target = 0;
else if (hasDataIMU())
float pitch = getPitchIMU();
float target_pitch = lpf_pitch_cmd(pid_vel((motor1.shaft_velocity + motor2.shaft_velocity) / 2 - lpf_throttle(throttle)));
float voltage_control = pid_stb(target_pitch - pitch);
float steering_adj = lpf_steering(steering);
motor1.target = voltage_control + steering_adj;
motor2.target = voltage_control - steering_adj;
commander.run();
handleBluetooth(bluetooth);
void handleBluetooth(Stream &bt_port)
int inByte;
if (bt_port.available() > 0)
while (bt_port.available())
inByte = bt_port.read();
inByte = inByte - 100;
if (inByte == 155)
steering = 0;
throttle = 0;
state = 1;
else if (inByte == 154)
steering = 0;
throttle = 0;
state = 0;
else if (inByte >= -100 && inByte <= 100)
throttle = max_throttle * ((float)inByte) / 100.0;
else if (inByte >= 110 && inByte <= 150)
steering = max_steering * ((float)(inByte - 130.0)) / 20.0;
else
steering = 0;
throttle = 0;
bt_port.flush();
serial port:
Initializing I2C devices...
Testing device connections...
MPU6050 connection successful
Initializing DMP...
-2302.00000, -2333.00000, 1532.00000, 151.00000, 101.00000, 40.00000
Enabling DMP...
DMP ready! Waiting for first interrupt...
Adjusting DMP sensor fusion gain...
MOT: Monitor enabled!
MOT: Init
MOT: Enable driver.
MOT: Init
MOT: Enable driver.
MOT: Align sensor.
MOT: sensor_direction==CW
MOT: PP check: fail - estimated pp: 18.06
MOT: Zero elec. angle: 1.86
MOT: No current sense.
MOT: Ready.
MOT: Align sensor.
MOT: sensor_direction==CCW
MOT: PP check: fail - estimated pp: 1.08
MOT: Zero elec. angle: 1.83
MOT: Ready.
[ 22552][E][Wire.cpp:513] requestFrom(): i2cRead returned Error 263
[ 39614][E][Wire.cpp:513] requestFrom(): i2cRead returned Error 263
[ 61501][E][Wire.cpp:513] requestFrom(): i2cRead returned Error 263
The error “i2cRead returned Error” is worrying me
I added i2c configuration to the imou _helpers file
int initIMU() {
Wire.begin(0, 4);
Wire.setClock(400000); // 400kHz I2C clock. Comment this line if having compilation difficulties
I use a 9V 800mA power supply, and I’m wondering if the power supply might be the problem.
