Hello guys!
Just a quick question for you, if I want to control two motors with one ESP32 is it possible to do it like this or do I need to use RTOS or some other operating system?
Here is the code I was talking about
#define M1_PWM_U 16
#define M1_PWM_V 4
#define M1_PWM_W 32
#define M1_HA 25
#define M1_HB 26
#define M1_HC 27
#define M2_PWM_U 27
#define M2_PWM_V 26
#define M2_PWM_W 25
#define M2_HA 4
#define M2_HB 15
#define M2_HC 35
float target_velocity_common = 400.0; // rad/s
BLDCMotor motor1 = BLDCMotor(1);
BLDCMotor motor2 = BLDCMotor(1);
BLDCDriver3PWM driver1 = BLDCDriver3PWM(M1_PWM_U, M1_PWM_V, M1_PWM_W);
BLDCDriver3PWM driver2 = BLDCDriver3PWM(M2_PWM_U, M2_PWM_V, M2_PWM_W);
HallSensor sensor1 = HallSensor(M1_HA, M1_HB, M1_HC, 1);
HallSensor sensor2 = HallSensor(M2_HA, M2_HB, M2_HC, 1);
// void doA1(){sensor1.handleA();}
// void doB1(){sensor1.handleB();}
// void doC1(){sensor1.handleC();}
// void doA2(){sensor2.handleA();}
// void doB2(){sensor2.handleB();}
// void doC2(){sensor2.handleC();}
sensor1.init();
sensor2.init();
motor1.linkSensor(&sensor1);
motor2.linkSensor(&sensor2);
driver1.voltage_power_supply = 12;
driver2.voltage_power_supply = 12;
if (!driver1.init() || !driver2.init()) {
Serial.println(“Driver init failed!”);
while (1);
motor1.linkDriver(&driver1);
motor2.linkDriver(&driver2);
motor1.controller = MotionControlType::velocity;
motor2.controller = MotionControlType::velocity;
motor1.voltage_sensor_align = 1;
motor2.voltage_sensor_align = 1;
motor1.PID_velocity.P = 0.01f;
motor1.PID_velocity.I = 0.1f;
motor1.PID_velocity.D = 0;
motor1.voltage_limit = 5;
motor1.PID_velocity.output_ramp = 100;
motor1.LPF_velocity.Tf = 0.05f;
motor1.sensor_direction = Direction::CW;
motor2.PID_velocity = motor1.PID_velocity;
motor2.voltage_limit = motor1.voltage_limit;
motor2.LPF_velocity.Tf = motor1.LPF_velocity.Tf;
motor2.sensor_direction = Direction::CW;
motor1.init();
motor2.init();
motor1.initFOC();
motor2.initFOC();
// FOC Loops
motor1.loopFOC();
motor2.loopFOC();
motor1.move(target_velocity_common);
motor2.move(target_velocity_common);
