RP2040 with AS5048A
Thanks @runger, this is the code, which now compiles on arduino IDE but not on platformio. But also sends me 00,0 on terminal. The wiring is absolutely sure is ok, and connected to SPI0 on pico.
#include "Arduino.h"
#include "Wire.h"
#include "SPI.h"
#include "SimpleFOC.h"
#include "SimpleFOCDrivers.h"
#include "encoders/as5048a/MagneticSensorAS5048A.h"
// these are GPIO numbers, so pin 13 is the one labeled GPIO13 on the board
#define PIN_CS 22 //13
#define PIN_CLK 18 //10
#define PIN_MISO 16 //12
#define PIN_MOSI 19 //11
arduino::MbedSPI mySPI(PIN_MISO, PIN_MOSI, PIN_CLK);
MagneticSensorSPIConfig_s myAS5048_SPI = {
  .spi_mode = SPI_MODE1,
  .clock_speed = 1000000,
  .bit_resolution = 14,
  .angle_register = 0x3FFF,
  .data_start_bit = 13,
  .command_rw_bit = 14,
  .command_parity_bit = 15
MagneticSensorSPI sensor = MagneticSensorSPI(myAS5048_SPI, PIN_CS);
  // monitoring port
  sensor.init(&mySPI);
  // this function reads the sensor hardware and
  // has to be called before getAngle nad getVelocity
  sensor.update();
  Serial.print("\t");
  delay(100); // 10x per second is enough for printing the angle. remove the delay when actually running a motor
Can you post your platformio.ini? The problem is probably here if it is compiling on Arduino IDE
Sure, here it is.
;   Build options: build flags, source filter
;   Upload options: custom upload port, speed and extra flags
[env:pico]
platform = raspberrypi
board = pico
framework = arduino
lib_archive = false
monitor_speed = 115200
lib_deps =
	askuric/Simple FOC@^2.3.0
	simplefoc/SimpleFOCDrivers@^1.0.4
Very strange, second times compiles without error, but with 7 problems.
@runger Could you please take a look at this:
I decided to return to a previous code, and installed a different board with board manager in IDE. This board is exactly the same, what I’m using, the Wiznet W6100-EVB-pico.
The compiler throws this errors for this kind of pico, but with a regular pico runs without errors. Maybe here is the problem with the SPI.
This is the code:
#include "Wire.h"
#include "SPI.h"
#define SENSOR1_CS 22 // some digital pin that you're using as the nCS pin
MagneticSensorAS5048A sensor1(SENSOR1_CS);
    sensor1.init();
// update the sensor (only needed if using the sensor without a motor)
    sensor1.update();
    // get the angle, in radians, including full rotations
    float a1 = sensor1.getAngle();
Serial.print(a1);
    // get the velocity, in rad/s - note: you have to call getAngle() on a regular basis for it to work
    float v1 = sensor1.getVelocity();
    // get the angle, in radians, no full rotations
    float a2 = sensor1.getCurrentAngle();
    // get the raw 14 bit value
    uint16_t raw = sensor1.readRawAngle();
    // read the CORDIC magnitude value, a measure of the magnet field strength
    float m1 = sensor1.readMagnitude();
    // check for errors
    if (sensor1.isErrorFlag()) {
        AS5048Error error = sensor1.clearErrorFlag();
        if (error.parityError) { // also error.framingError, error.commandInvalid
            // etc...
And the errors:
/Users/m2mini/Documents/Arduino/libraries/Simple_FOC/src/current_sense/hardware_specific/rp2040/rp2040_mcu.cpp:18:44: error: ‘ADC_CS_START_ONCE_BITS’ was not declared in this scope
  • 18 | alignas(32) const uint32_t trigger_value = ADC_CS_START_ONCE_BITS; // start once*
/Users/m2mini/Documents/Arduino/libraries/Simple_FOC/src/current_sense/hardware_specific/rp2040/rp2040_mcu.cpp: In member function ‘bool RP2040ADCEngine::init()’:
/Users/m2mini/Documents/Arduino/libraries/Simple_FOC/src/current_sense/hardware_specific/rp2040/rp2040_mcu.cpp:148:5: error: ‘adc_init’ was not declared in this scope
  • 148 | adc_init();*
/Users/m2mini/Documents/Arduino/libraries/Simple_FOC/src/current_sense/hardware_specific/rp2040/rp2040_mcu.cpp:153:13: error: ‘adc_gpio_init’ was not declared in this scope; did you mean ‘pio_gpio_init’?
  • 153 | adc_gpio_init(i+26);*
  •  |             pio_gpio_init*
/Users/m2mini/Documents/Arduino/libraries/Simple_FOC/src/current_sense/hardware_specific/rp2040/rp2040_mcu.cpp:158:5: error: ‘adc_set_round_robin’ was not declared in this scope
  • 158 | adc_set_round_robin(enableMask);*
/Users/m2mini/Documents/Arduino/libraries/Simple_FOC/src/current_sense/hardware_specific/rp2040/rp2040_mcu.cpp:159:5: error: ‘adc_fifo_setup’ was not declared in this scope
  • 159 | adc_fifo_setup(*
/Users/m2mini/Documents/Arduino/libraries/Simple_FOC/src/current_sense/hardware_specific/rp2040/rp2040_mcu.cpp:169:9: error: ‘adc_set_clkdiv’ was not declared in this scope; did you mean ‘pwm_set_clkdiv’?
  • 169 | adc_set_clkdiv(0);*
  •  |         pwm_set_clkdiv*
/Users/m2mini/Documents/Arduino/libraries/Simple_FOC/src/current_sense/hardware_specific/rp2040/rp2040_mcu.cpp:172:9: error: ‘adc_set_clkdiv’ was not declared in this scope; did you mean ‘pwm_set_clkdiv’?
  • 172 | adc_set_clkdiv(48000000/samples_per_second);*
  •  |         pwm_set_clkdiv*
/Users/m2mini/Documents/Arduino/libraries/Simple_FOC/src/current_sense/hardware_specific/rp2040/rp2040_mcu.cpp:185:10: error: ‘adc_hw’ was not declared in this scope
  • 185 | &adc_hw->fifo, // source*
/Users/m2mini/Documents/Arduino/libraries/Simple_FOC/src/current_sense/hardware_specific/rp2040/rp2040_mcu.cpp: In member function ‘void RP2040ADCEngine::start()’:
/Users/m2mini/Documents/Arduino/libraries/Simple_FOC/src/current_sense/hardware_specific/rp2040/rp2040_mcu.cpp:226:13: error: ‘adc_select_input’ was not declared in this scope
  • 226 | adc_select_input(i); // set input to first enabled channel*
/Users/m2mini/Documents/Arduino/libraries/Simple_FOC/src/current_sense/hardware_specific/rp2040/rp2040_mcu.cpp:235:5: error: ‘adc_run’ was not declared in this scope
  • 235 | adc_run(true);*
/Users/m2mini/Documents/Arduino/libraries/Simple_FOC/src/current_sense/hardware_specific/rp2040/rp2040_mcu.cpp: In member function ‘void RP2040ADCEngine::stop()’:
/Users/m2mini/Documents/Arduino/libraries/Simple_FOC/src/current_sense/hardware_specific/rp2040/rp2040_mcu.cpp:243:5: error: ‘adc_run’ was not declared in this scope
  • 243 | adc_run(false);*
/Users/m2mini/Documents/Arduino/libraries/Simple_FOC/src/current_sense/hardware_specific/rp2040/rp2040_mcu.cpp:247:5: error: ‘adc_fifo_drain’ was not declared in this scope
  • 247 | adc_fifo_drain();*
exit status 1
Compilation error: exit status 1
This error has already been fixed, IIRC, but you have to use the dev branch version of the library, IIRC.
Or wait for the next release version, which will include the fix…
Sorry for the noob question but where is located the dev branch version of the library?
This is the DEV?
Almost there…
I have now an arduino ide error with the dev version, which seems to be in 2.1.1 but the same in 2.1.2 nigtly.
Property 'upload.tool.serial' is undefined
Yes, you found it!
This error should not really happen - you can install the dev version by replacing the default version of the library, which should be in your Documents/Arduino/libraries folder.
I think this error is not related to the simpleFOC library, this is a known error from arduino IDE 2.1, but I can not upload the code.
Finally, I’ve got the sensor signal. Here is the working code:
#include "SPI.h"
#define SPI_2_MISO  12
#define SPI_2_MOSI  15
#define SPI_2_SCK   14
#define SENSOR1_CS  13 // some digital pin that you're using as the nCS pin
MagneticSensorAS5048A sensor1(SENSOR1_CS, true);
MbedSPI spi2(SPI_2_MISO, SPI_2_MOSI, SPI_2_SCK);
  spi2.begin();
  sensor1.init(&spi2);
  sensor1.update();
  Serial.println(a1);
  // regular basis for it to work
  // Serial.println(a2);
  // check for errors
                             // etc...
Hi guys.
Sorry to dig this up but I’m having some trouble with a very similar setup. I’m using the Raspberry pi pico with the Earle Philhower core and getting the same error message with the SPI.
error: no matching function for call to ‘arduino::HardwareSPI::HardwareSPI(int, int, int)’
#include "Wire.h"
#include "SPI.h"
// MagneticSensorSPI(int cs, float _cpr, int _angle_register)
// cs              - SPI chip select pin
// bit_resolution  - sensor resolution
// angle_register  - (optional) angle read register - default 0x3FFF
//MagneticSensorSPI as5047u = MagneticSensorSPI(10, 14, 0x3FFF);
// or quick config
#define PIN_CS 13
#define PIN_CLK 10
#define PIN_MISO 12
#define PIN_MOSI 11
SPIClass mySPI(PIN_MOSI, PIN_MISO, PIN_CLK);
MagneticSensorSPIConfig_s myAS5147_SPI = {
I’ve tried the way runger suggested above and I’m not sure what to do next.
I’m using a AS5147U magnetic sensor and the same setup was working well on an Arduino mega. The problem I’ve run into is I don’t know how to declare what pins the SPI uses in the code.
  • Update, I’ve got so far as to have the chip select working. I have each channel of the SPI on my oscilloscope.
Here’s the code I’m trying to get working:
#include "SPI.h"
//#include "SimpleFOCDrivers.h"
// or quick config
#define PIN_CS 13
#define PIN_CLK 10
#define PIN_MISO 12
#define PIN_MOSI 11
#define PIN_CS 13
#define PIN_CLK 10
#define PIN_MISO 12
#define PIN_MOSI 11
SPISettings spisettings(1000000, MSBFIRST, SPI_MODE1);
bool setRX(12); // or setMISO()
bool setCS(13);
bool setSCK(10);
bool setTX(11); // or setMOSI()
MagneticSensorSPI sensor = MagneticSensorSPI(AS5147_SPI, 13);
// BLDCDriver3PWM(pwmA, pwmB, pwmC, (en optional))
BLDCDriver3PWM driver = BLDCDriver3PWM(7, 9, 6, 8);
float target_angle = 0;
void onTarget(char* cmd){ command.scalar(&target_angle, cmd); }
  //SPI.begin();
  //sensor.init(&mySPI);
  driver.voltage_limit = 10;
  if(!driver.init()){
    return;
  // default P=0.5 I = 10
  motor.PID_velocity.P = 0.2;
  motor.PID_velocity.I = 20;
  //default voltage_power_supply
  motor.voltage_limit = 6;
  motor.LPF_velocity.Tf = 0.01;
  // angle P controller
  // default P=20
  motor.P_angle.P = 20;
  // default 20
  motor.velocity_limit = 4;
  command.add('T', onTarget, "target angle");
  // monitoring port
  Serial.println("Set the target angle using serial terminal:");
Hey,
Only certain pins can be used for SPI, I assume you checked them against a pin out diagram?
Have you tried to use the dedicated AS5047U driver we have in the drivers library? It will let you use this sensors advanced features…
It does sound like your issues are related to the SPI setup though, and it looks to me like you’re close.
I have got it working!
The problem was which SPI pins I was using there. I thought I could just use any of the SPI capable pins if I configured them in the setup. However testing around it seems the SPI was being output on the Pi Picos default SPI pins despite me trying to set other ones.
As for the sensor, it seems to work as is. I haven’t had a look at the AS5047U drive yet. Seems like the AS5047U and AS5147U are pretty similar. I think the AS5147U board was the only one I could find at mouser.
Here is the code using the AS5147U on the Pi Pico with Earle Philhower’s core, for future reference.
#include "SPI.h"
MagneticSensorSPI sensor = MagneticSensorSPI(AS5147_SPI, 17);
  //SPI.begin();
  if(!driver.init()){
    return;
  // default P=20
  // default 20
  // monitoring port
