// MagneticSensorI2C(uint8_t _chip_address, float _cpr, uint8_t _angle_register_msb)
// chip_address I2C chip address
// bit_resolution resolution of the sensor
// angle_register_msb angle read register msb
// bits_used_msb number of used bits in msb register
// make sure to read the chip address and the chip angle register msb value from the datasheet
// also in most cases you will need external pull-ups on SDA and SCL lines!!!
// For AS5058B
// MagneticSensorI2C sensor = MagneticSensorI2C(0x40, 14, 0xFE, 8);
// Example of AS5600 configuration
// monitoring port
// configure i2C
Wire.setClock(400000);
Serial.println(“Sensor ready”);
// this function reads the sensor hardware and
// has to be called before getAngle nad getVelocity
sensor.update();
Serial.print(“\t”);
When using this code the motor is stationary but not moving.
What’s the matter?
