I’m interested in building a very small actuator.
To achieve the smallest size and lowest cost, I need to be able to estimate speed and position without a sensor (I considered attaching something like a potentiometer to the drive shaft, but quickly gave up). So, I’d like to ask a few questions in this community.
The approximate size is a 10-15mm diameter motor.
Because of its small size, the load it drives is small.
If this driver project is successful, I plan to build a small robot that can express human posture.
- Motor Selection: BLDC or Stepper Motor?
Due to the nature of this project, the motor should be suitable for position control, not continuous high-speed rotation. I think a stepper motor would be appropriate in this case,
but which motor would you choose? Please explain your reasons.
Recommended Driver IC
If using a BLDC motor, I recommend using the DRV8311. When using a stepper motor, I plan to drive it using a combination of two full-bridge drivers.
If you have a recommended driver IC, please share it. -
MCU Selection
Since the driver needs to be small, the MCU must also be small.
I’ve been using STM32 for a long time, so I’m considering a small and inexpensive option, such as the STM32F103C8T. Is this a suitable choice?
Or, please recommend another MCU (preferably an STM32). -
Other Theories Required for Sensorless Motors
Since I had to write the driver code myself, I had to study theories like FOC and IPD. Any resources that could help me understand these theories would be greatly appreciated.
Thank you!
Hi. Anyone here can tell me if this library is compatible with the Arduino Giga board? And I'm not sure I should ask this, I'm pretty new at this. Can I configure two sensors, like a dual-encoder setup for absolute position? Thanks in advance. I'm eager to start programming using this library.
– Os_R.MYes, you can attach two encoders to a STM32 MCU… STM32H5 I have not tested yet, if you try it please let us know how it goes. STM32H5 is different from Arduino Giga which has a STM32H7 dual core MCU.
– runger
