Hello all,
during my time now with SimpleFOC I had my system running quite well with closed loop angle control.
I just needed a bit more performance thats why i wanted to implement current sensing.
I tried adapting the code from https://community.simplefoc.com/t/problem-with-b-g431b-esc1-current-sensing/3417 but then the motor would not turn all the time and when it turned it had a big delay.
Then i tried the example code for the b_g431_esc that you can see below. In this code the setup for current sensing is already there. but as soon as I am uncommenting
, the motor does not move at all. Is this just a thing of tuning the PID controllers or am I making a bigger mistake ?
* B-G431B-ESC1 position motion control example with encoder
// Motor instance
BLDCMotor motor = BLDCMotor(4,0.4,601);
// encoder instance
Encoder encoder = Encoder(PB6,PB7,2048);
// channel A and B callbacks
void doIndex(){encoder.handleIndex();}
void doTarget(char* cmd) { command.motion(&motor, cmd); }
encoder.init();
motor.linkSensor(&encoder);
driver.voltage_power_supply = 13;
// current sensing
currentSense.init();
// no need for aligning
// aligning voltage [V]
//motor.torque_controller = TorqueControlType::foc_current;
// contoller configuration
motor.PID_velocity.P = 0.2;
motor.PID_velocity.I = 20;
motor.voltage_limit = 12;
motor.current_limit = 6;
motor.LPF_velocity.Tf = 0.01;
// angle P controller
motor.P_angle.P = 20;
motor.velocity_limit = 500;
// motor.monitor();
