Hello everyone, I’ll just say that I’m using Google Translate to write this text. I apologize in advance for any distorted words.
I’m trying to run a MT5208 340kV BLDC motor on an Arduino NANO microcontroller using a homemade IR2401S driver (The driver is powered separately from the motor). I assembled it according to the schematic below:
I’m using the code from the Simple FOC example to move the motor between 1 radian and -1 radian every second. If I specify open-loop control in the code, i.e., “motor.controller = MotionControlType::angle_openloop,” the motor does indeed rotate at the specified angles every second, but some vibration is felt (the motor is fully functional and operates via an ESC controller). Here’s code:
motor.PID_velocity.P = 0.2;
motor.PID_velocity.I = 20;
motor.PID_velocity.D = 0.001;
motor.LPF_velocity.Tf = 0.01;
motor.P_angle.P = 20;
motor.velocity_limit = 4;
motor.voltage_limit = 10;
float target_angle = 1;
long timestamp_us = _micros();
if(_micros() - timestamp_us > 1e6) {
target_angle = -target_angle;
motor.move(target_angle);
But if I simply specify “motor.controller = MotionControlType::angle” and connect the as5600 magnetic encoder, the motor starts to jerk violently, but still turns at the specified angles. (The encoder is also working; for one motor rotation, the encoder shows 6.28 radians.) Here’s the code with the encoder connected:
MagneticSensorI2C encoder = MagneticSensorI2C(AS5600_I2C);
encoder.init();
motor.linkSensor(&encoder);
if (_micros() - timestamp_us > 1e6) {
Unfortunately, I can’t provide the driver output data via an oscilloscope, as I don’t have one. Please help me figure out what I’m doing wrong.
Try Set voltage to 0.5 Voltage.
– viktornichko
