Hello everyone,
I’ve been experimenting with the MKS ODrive Mini recently, but I’m having problems with the serial communication.
I can see the debug output on the onboard USB port, but I can’t send any commands through it.
Is there any way to make this work?
Thanks in advance for any help!
Thats my Code:
Odrive robotics' hardware is one of the best BLDC motor foc supporting hardware out there.
This is an example code that can be directly uploaded to the Odrive using the SWD programmer.
This code uses an magnetic spi sensor AS5047 and a BLDC motor with 11 pole pairs connected to the M0 interface of the Odrive.
This is a short template code and the idea is that you are able to adapt to your needs not to be a complete solution. :D
// Odrive M0 motor pinout
#define M0_INH_A PA8
#define M0_INH_B PA9
#define M0_INH_C PA10
#define M0_INL_A PB13
#define M0_INL_B PB14
#define M0_INL_C PB15
// M0 currnets
#define M0_IB PC0
#define M0_IC PC1
// Odrive M0 encoder pinout
#define M0_ENC_A PB4
#define M0_ENC_B PB5
#define M0_ENC_Z PC9
#define M0_ENC PA15
// Odrive M1 motor pinout
#define M1_INH_A PC6
#define M1_INH_B PC7
#define M1_INH_C PC8
#define M1_INL_A PA7
#define M1_INL_B PB0
#define M1_INL_C PB1
// M0 currnets
#define M1_IB PC2
#define M1_IC PC3
// Odrive M1 encoder pinout
#define M1_ENC_A PB6
#define M1_ENC_B PB7
#define M1_ENC_Z PC15
// M1 & M2 common enable pin
#define EN_GATE PB12
// SPI pinout
#define SPI3_SCL PC10
#define SPI3_MISO PC11
#define SPI3_MOSO PC12
MagneticSensorSPIConfig_s AS5047P_SPI = {
.spi_mode = SPI_MODE1,
.clock_speed = 1000000,
.bit_resolution = 14,
.angle_register = 0x3FFF,
.data_start_bit = 13,
.command_rw_bit = 14,
.command_parity_bit = 15
// Motor instance
BLDCMotor motor = BLDCMotor(20);
BLDCDriver6PWM driver = BLDCDriver6PWM(M0_INH_A,M0_INL_A, M0_INH_B,M0_INL_B, M0_INH_C,M0_INL_C, EN_GATE);
// low side current sensing define
// 0.0005 Ohm resistor
// gain of 10x
// current sensing on B and C phases, phase A not connected
LowsideCurrentSense current_sense = LowsideCurrentSense(0.0005f, 10.0f, _NC, M0_IB, M0_IC);
// MagneticSensorSPI(int cs, float _cpr, int _angle_register)
// config - SPI config
// cs - SPI chip select pin
MagneticSensorSPI sensor = MagneticSensorSPI(AS5147_SPI, M0_ENC);
SPIClass SPI_3(SPI3_MOSO, SPI3_MISO, SPI3_SCL);
void setup(){
// enable more verbose output for debugginge
driver.pwm_frequency = 20000;
driver.voltage_limit = 12;
// driver init
sensor.init(&SPI_3);
// control loop type and torque mode
// max voltage allowed for motion control
motor.voltage_limit = 8.0;
// alignment voltage limit
//motor.monitor_variables = _MON_CURR_Q | _MON_CURR_D;
//motor.monitor_downsample = 1000;
command.add('M', doMotor, "motor M0");
// initialise motor
// link the driver
// init the current sense
current_sense.init();
// init FOC
delay(1000);
void loop(){
// foc loop
// motion control
// monitoring
