There is no real part, those show as parts but they are just footprints, you don’t need to solder anything.
Which parts are out of stock? Please post the part numbers and I will check for synonyms.
No, this is not normal for one board. There is something going on with the order. Usually when you order from JLC they automatically put 5 boards, can you check? You probably ordered 5 board, but you were thinking you ordered 1 board. E60 for 5 boards is normal, since I am not sure what the cost in Europe is including delivery. Usually FedEx or DHL express is about $40 so you get about E60 for 5 boards and E30 for delivery, that’s about right.
Please familiarize yourself very carefully with the order process, if this is your fist time, it may be good for you to re-order a few times, up to the payment, then cancel, re-order, and learn how to do it. There is nothing wrong with ordering ten times, canceling an order ten times until you get the process, as long as you do not pay, JLC doesn’t care.
You are very welcome, I’m glad people are using them.
I may try to do that in the future however sharing directly on EasyEDA allows people to clone and order using the EasyEDA integrated process, as well as learn how to do PCB design themselves. My designs are more of providing an educational experience and a base for doing something more, rather than production. I will consider creating a github repo, I have an intern (a college student) that may be interested in doing this. Personally, I’m more of a design and forget and move on.
When you order this is where you specify your number of boards, at PCB Qty. The default is 5.
When you get to the BOM page, you will see that two components are missing. One is the driver itself, so wow, they are really out of stock, huh… That sucks! Well good news they still have the TI’s driver which is actually a lot better but a little more expensive, so you can replace it directly on the order page like that
Search for DRV8313. Click on the Select button!
Next one missing is the resonator. That is a real problem because this resonator is very particular and you cannot replace it with anything else. Let me see if we can find another one, but doubtful. Hold on…
OK there are a little bit left of part number C341524. If this is out of stock, get C907975, search for the part on the BOM order page, and click on Select.
Your BOM will look like this:
When you click Next, your order page will look like this:
This is for 5 boards, not one !!! So for one board, the cost is $17 which is pretty good, considering.
If you order 10 boards, the cost per board will drop to $15 which is about E13, not sure of the latest exchange rate. However do not forget you must pay shipping so your shipping will add to the cost.
Good luck!
PS One last thing, JLC usually gives you $9 discount per order, make sure you pick that, it will lower your cost, on the order payment page.
