Problem for stepper motor in close loop mode
hello everyone,
I’m using STM32F103C8T6 blue pill bord, MA730 sensor, and L298N driver. Openloop work and sensor output are correct, but once enter torque mode or angle mode motor stop spining, I follow the Stepper motor control example setting everything up, still can’t get it working.
what should i do? any tips
Thank you !
Hey @dj140, we need a it more info to help you out Can you share your code with us?
it just the standard example code :
// Stepper motor instance
// Stepper driver instance
StepperDriver4PWM driver = StepperDriver4PWM(PA1, PA3, PB0, PA2, PB8, PB9);
MagneticSensorSPI encoder = MagneticSensorSPI(MA730_SPI, PA4);
// commander interface
  encoder.init();
  motor.linkSensor(&encoder);
  // choose FOC modulation
  motor.PID_velocity.P = 0.2;
  motor.PID_velocity.I = 20;
  motor.voltage_limit = 12;
  motor.LPF_velocity.Tf = 0.01;
  // angle loop controller
  motor.P_angle.P = 20;
  // angle loop velocity limit
  motor.velocity_limit = 50;
  // monitoring port
  // initialise motor
  motor.target = 2;
  // define the motor id
  delay(1000);
  Serial.print(encoder.getAngle());
  Serial.print("\t");
Ok, can you explain more the behavior you’re experiencing? do you feel any type of torque, is the motor getting hot, how much current is the power supply drawing, etc.
It’ll be easier to help you out with more information.
I’m using 12V 1A power supply. When power on the motor rotates a little bit from left to right, after that it draw a lot of current, motor slowly getting warm. I can twist the rotor by hand, but it won’t return to its original position.
Thanks for helping.
