I’m testing the SimpleFOC library for the first time on a B-G431B-ESC1 and a BLDC motor like the flipsky 5065 270KV. I am currently using Arduino IDE with STM32duino core.
After some tests in which at startup my power supply went into OCP and consequently the sensor alignment failed (verified with motor.monitor()), by disabling the OCP of the power supply the sensor alignment procedure seems to be going successfully and the motor move smoothly (But the power supply voltage drop to 10 V due to the current limit). Again using the motor.monitor() seems that the position reference coming from the hall sensors is fine and precise.
However after this procedure, by trying to rotate manually the rotor, the position control work but in a strange fashion. In the sense that there are positions in which the motor stick the position and with a little manual help, start to jerky rotate till to the target position. The strange things is that this behavior seems to be accentuated in the clockwise direction.
The setup was tested before with the ST motor pilot (it works good) and motor profiler, and such motor parameters are reported on the arduino sketch.
One things that i’ve tried to tune (for now i haven’t touch the PID) is the current_limit (that seems to impact only on the motor.move() and not in the motor.initFOC()) and provide an zero_electric_offset to motor.initFOC() without solve the problem (in the ST motor control was 60°).
Right now i’ve saw that voltage_sensor_align is used in the alignSensor() and so by tuning this parameter i should avoid the OCP, but i’ve not tested yet.
So to conclude, I wanted to ask you some advice on how to calibrate the control correctly, maybe I should start with something as simple as speed control?
i leave the code of the sketch
* B-G431B-ESC1 position motion control example with encoder
// software interrupt library
const int motorPolePairs = 9;
// Motor instance
BLDCMotor motor = BLDCMotor(motorPolePairs);
//(resistance, gain, pin_1_2_3)
// encoder instance
HallSensor sensor = HallSensor(A_HALL1, A_HALL2, A_HALL3, motorPolePairs);
// channel A and B callbacks
void doA(){sensor.handleA();}
void doB(){sensor.handleB();}
void doC(){sensor.handleC();}
// angle set point variable
float target_angle = 0;
// initialize sensor hardware
motor.phase_resistance = 0.2; // [Ohm]
motor.current_limit = 5; // [Amps] - if phase resistance defined
//motor.voltage_limit = 0.5; // [V] - if phase
// resistance not defined
motor.velocity_limit = 50; // [rad/s] 5 rad/s cca 50rpm
// current sensing
currentSense.init();
// no need for aligning
// aligning voltage [V]
// contoller configuration
motor.PID_velocity.P = 0.2f;
motor.PID_velocity.I = 2;
motor.voltage_limit = 6;
// angle P controller
motor.P_angle.P = 20;
motor.velocity_limit = 4;
motor.monitor_variables = _MON_ANGLE; // default _MON_TARGET | _MON_VOLT_Q | _MON_VEL | _MON_ANGLE
// Serial.println(F("Motor init."));
// Serial.println(F("Motor align."));
Serial.println(F("Init FOC"));
// Arduino UNO loop ~1kHz
// Bluepill loop ~10kHz
motor.move(target_angle);
// motor.monitor();
