Hi All,
I’ve got a stepper motor I’m trying to use with simpleFOC library, setup:
-Motor: 200 PPR stepper motor
-Controller: Arduino Uno (ATMega328P)
-Driver: 4x BTS7960 (40A 25V Integrated Half-bridge driver+MOSFET)
+I have successfully used the Arduino “stepper” library to drive this exact configuration with classical stepper motor commutation and it works great.
I can get the motor spinning with simpleFOC in openloop angle/velocity, but the motion is rough, there’s a once per revolution thump, and (in angle mode) when the motor stops it sometimes (depending on the angle I stop at) makes a periodic thumping/clicking noise. I am using openloop modes for now because I figured I should get it working first with that.
My app is listed below.
StepperMotor motor = StepperMotor(64, 3);
StepperDriver4PWM driver = StepperDriver4PWM(5, 6, 9, 10);
void doTarget(char* cmd) {
command.scalar(&motor.target, cmd);
void doLimit(char* cmd) {
command.scalar(&motor.voltage_limit, cmd);
void doVelocity(char* cmd) {
command.scalar(&motor.velocity_limit, cmd);
// set enable lines high
pinMode(1, OUTPUT); pinMode(2, OUTPUT); pinMode(3, OUTPUT); pinMode(4, OUTPUT);
digitalWrite(1, 1); digitalWrite(2, 1); digitalWrite(3, 1); digitalWrite(4, 1);
driver.voltage_limit = 5;
motor.voltage_limit = 4; // [V]
// limit/set the velocity of the transition in between
// target angles
motor.velocity_limit = 2 * 3.141592; // [rad/s] cca 50rpm
// open loop control config
// init motor hardware
command.add(‘V’, doVelocity, “movement velocity”);
motor.useMonitoring(Serial); // strange compiler error without this
motor.target = 2 * 3.141592;
Serial.println(“Motor ready!”);
Serial.println(“Set target position [rad]”);
// to turn the motor “backwards”, just set a negative target_velocity
//motor.move(target_velocity);
