Whatever the value you set for PID_velocity.limit during setup, motor.init()
will always change it back to 0.2 (because of this line I guess). Is it the expected behavior?
I confirm I believe there’s a bug with the velocity limit when using current sensing: if you don’t set motor.PID_velocity.limit
to somehting after motor.init()
, the motor won’t run because the velocity PID limit is set to 0.2 by default:
SPIClass SPI_3(PC12, PC11, PC10);
MagneticSensorSPI sensor(PD2, 14, 0x3FFF);
InlineCurrentSense current_sense(0.01, 50.0, A0, A2);
void doMotor(char* cmd){ command.motor(&motor, cmd); }
sensor.init(&SPI_3);
driver.voltage_power_supply = 14.5;
motor.velocity_limit = 50;
motor.voltage_limit = 10.0;
motor.PID_velocity.P = 0.1;
motor.PID_velocity.I = 8;
motor.PID_velocity.output_ramp = 1000.0;
motor.LPF_velocity.Tf = 0.005;
motor.monitor_downsample = 0;
motor.monitor_variables = 0xFF;
current_sense.init();
// THE BUG: here you need to set motor.PID_velocity.limit to something reasonable , otherwise
// the motor won't turn
motor.PID_velocity.limit = 10;
motor.target = 3;
Serial.println(F("Motor commands sketch | Initial motion control > torque/voltage : target 1V."));
(tested with both SimpleFOC v2.1.1 and v2.2)
Hey @quentin,
You are right. I’ll update this for the next release.
I forgot to deal with it for this one
