Periodic Jerk in velocity control mode
New here and have tried to search for this issue without luck, perhaps I didn’t have the correct terminology?
I am running Simple FOC Mini, AS5600 and ESP32-C6 Super Mini.
Overall I can get things working, including angle control. However, when I run velocity control to tune the PID parameters there is a periodic jerk in the motion when the speeds are over approx. 50 r/s.
The period of this disruption is around 2 sec, regardless of the speed.
https://youtu.be/O66ddPv0T7E
Any pointers on where I should start to look for a solution?
Thanks,
Mig
Seems I found the problem:
https://www.reddit.com/r/arduino/comments/1iuwcdq/psa_arduino_with_single_core_esp32s_adds_5ms/
Issue with single core ESP32 and Arduino.
Will try running in a separate task.
Did the RTOS solution work for you? I’m experiencing the same 2-second thunk.
Yes it solved the problem!
Wonderful! I’ll give it a shot. Thanks for the feedback.
I think I’ve been sitting here troubleshooting this thing so long that my brain has gone fuzzy and my vision cross-eyed. Would you mind posting your code showing how you implemented the solution?
Hi, Sorry for delayed response.
Below is the Arduino code that I used just to test if this fixed the problem.
For my actual code I moved all the initialisation out of the task.
[code]
#define I2C_SDA 6 // Custom SDA pin
#define I2C_SCL 7 // Custom SCL pin
TaskHandle_t TaskHandle_Motor; //For Motor Control
BLDCDriver3PWM driver = BLDCDriver3PWM(0, 1, 2, 3);
// encoder instance
//Encoder encoder = Encoder(2, 3, 500);
// channel A and B callbacks
//void doA(){encoder.handleA();}
//void doB(){encoder.handleB();}
void setup()
xTaskCreate(MyTaskMotor, “TaskMotor”, 2000, NULL, 1, &TaskHandle_Motor);
void loop()
vTaskDelete(NULL);
/*---------------------- Tasks ---------------------*/
static void MyTaskMotor(void* pvParameters)
unsigned long timer;
// if SimpleFOCMini is stacked in arduino headers
// on pins 12,11,10,9,8
// pin 12 is used as ground
//pinMode(12,OUTPUT);
//pinMode(12,LOW);
Wire.begin(I2C_SDA, I2C_SCL);
sensor.init(&Wire);
// aligning voltage [V]
// contoller configuration
motor.PID_velocity.P = 0.17f; //0.17
motor.PID_velocity.I = 0.55; //0.55
motor.PID_velocity.D = 0.0005; //0.0005
motor.voltage_limit = 10;
motor.LPF_velocity.Tf = 0.005f; //0.02
// angle P controller
motor.P_angle.P = 6;
motor.P_angle.D= 0.2; //.2
motor.P_angle.I= 0.001;
motor.velocity_limit = 50;
// add target command M
command.add(‘M’, doMotor, “motor”);
timer = micros();
while(1)
{ //Control Loop
if ((micros()-timer) >= 0)
  { timer = micros();
  // Arduino UNO loop  \~1kHz
  // Bluepill loop \~10kHz
  // motor.monitor();
[/code]
Good luck
