ParaTrain - a paragliding simulation and training device
So, here is the SimpleFOC based hobby project I have been working on for quite a while now. It is a simulator and training device for paragliding. It was virtually all new to me, which made it more challenging, but also very interesting. I have solid knowledge of electronics and have developed software for most of my life, but power electronics, motors, motor drivers, CAN bus and everything else involved here where white spots on my map, not even speaking of the physics behind such a simulator. Many paraglider pilots have simulators to play with their harnesses, but only very few will have one which is active, like mine:
(sorry for the mess in the background…)
Right now it performs two tasks. It serves as a training device by simulating the forces on the break lines as perceived when flying through turbulent air and it serves as input device for an online paragliding simulation game.
For the first task the torque of the motors is controlled to exert increasing forces the further down the breaks are pulled. There is a “neutral” point, where the force is 20N and this is the normal flying position. To simulate turbulances, this neutral point is randomly moved up or down and the pilot has to keep the force constant in order to fly straight. Forces and weight shifts are evaluated and a final score is given at the end of each training session. For the second task, the online simulator xcsim is controlled via a bluetooth connection to a PC and input from the breaklines and weight shifts is passed on to the online simulation.
The technical realisation connects several units with a CAN bus. The two break units are based on B-G431B-ESC1 boards, AS5047 sensors - on my first self designed PCB since 35 years, T-motor G60 kv55 motors, a lot of 3D printed stuff and of course SimpleFOC (torque mode, FOC current, sensor calibration).
Another unit contains 5V power supply, gyro sensor, signal distribution and motor temperature measurement, all built around an ESP32
Finally, the central control unit provides a very basic user interface, sends all the training commands to the motors and communicates with a PC using Bluetooth. This unit is also based on an ESP32.
The main difficulties which I encountered during the development - apart from lacking knowledge - were broken cheap CAN transceivers on breakout boards, dealing with strong BEMF if the pilot pulls the strings fast (solved with an active shunt, thanks @Valentine !), a loose magnet which still gave reasonable angle readings from the sensor (solved with a lot of help from this great forum!) and finding the right strategy for pulling the break lines in a realistic way. The last point caused some major software redesign since I started with position mode, which allowed me to nicely control the speed at which the neutral point varied, but the resulting motion never felt smooth, so I moved to torque mode with variable ramp parameters, which is very smooth now. Of course, I redesigned the mechanics several times and experimented with different motors too.
Next steps:
- Gain more real world flying experience (I am still a beginner) in order to tune the behavior even better.
- Simulate movements of the seatboard caused by wind/thermal forces. No idea yet how I will model this, but I know already it will require very strong motors if it shall be realistic…
If there are other paraglider pilots here with similar projects or ideas, I am very open to discussion. I had planned to make the design open source, but I don’t know if I will ever find the time required to clean it up sufficiently and to document everything so that other people could replicate the design.
Happy landings,
Chris
That’s a really amazing project!! It’s clear you’ve put so much work into it, and it looks like you’ve made something really impressive, and quite unique too. Congratulations!!!
Very impressive, thank you for sharing.
Please share a video! This might just be the coolest SimpleFOC project so far :slight_smile:
Thanks for the compliment, but it is by far not as spectacular as it may sound, all your robots are certainly far more complex. After all, I am just pulling on two strings. With more experience it would have been easy. Anyway, I have learned tons of new things and that was real fun! Once I have the seatboard movements implemented, it will be more interesting, but that is more something for the next winter, it is outdoor season now!
Wow too bad that I’ve only just seen your project here. I had the same Idea in mind and I already ordered the parts :slight_smile:
Ill try it with the 90KV eaglepower 8308 motor. And (also bec Ive seen your porject here too lare) Ill try to run it with a ODrive board and code.
I have the same aim in mind: Im more or less a beginner in paragliding and I can not go paragliding enough to train my muscle memory the active steering in turbulent air. Therefore I will build the simulator for myself.
Is there any way I could reach you directly, Chris? Im from Hamburg, Germany btw :slight_smile:
Would be great to share some ideas and ofc I would like to learn a bit from your project.
And Yes I already thought about a system to move the harness with linear actuators
Hi Lukas, I‘ll send you a DM.
I feel it is time for a short update before we enter any discussion, but let me start with a clear warning: Depending on how far you want to take it, this endeaver is far more complex, time consuming and expensive as you might think at the beginning, however, it is also a lot of fun of course!
Since my initial presentation here, I made several big steps forward. I can now not only simulate variable tension of the break lines, but I can also simulate roll movements of the harness, I can use it with a Meta Quest 3 to control GliderSim (a really nice VR paragliding simulation game) through BLE and I can receive force feedback from the VR game via BLE (my sim rig declares itself to the PC as a Bluetooth connected gamepad). Also, I made PCBs for the main user interface (display, buttons, two rotary encoders, runs all the controll software, communications and very simple physical flight model) and the sensor unit (IMU, temp sensors, CAN bus distribution, some power management). The next big step will be simulation of pitch movements, which is mostly a trade off between space for long levers and motor size, still quite some way to go there. Currently it looks as in the messy picture below.
The experience so far is:
  • Mechanical design is reasonable, use of standard Item profiles was a good decision because of the flexibility.
  • Especially for the break lines, haptics are very important, it is essential to use very low cogging motors. Motors must also be fairly strong and react fast to be realistic.
  • Managing BEMF is absolutely essential. Otherwise, if you pull hard on the breaks, you create significant overvoltage and destroy the electronics. I had to learn it the hard way. Current solution is usage of a shunt regulator as proposed by @Valentine. I am just experimenting with a regulator based on a MOSFET and a TL431 (smaller, cheaper, less heat), but Valentine’s proposal I would call well proven.
  • Modified (SPI, replaced potentiometer by an NTC) B-G431B-ESC1 drivers are well suitable so far although it is really tempting to make my own drivers, but too many interesting things to do…
  • Communication between all the MCUs via CAN bus works very nicely.
I had a look at the motors you are planning to use, but could not find information regarding pole pairs (probably “enough”) or torque. By the look, these are more made for drones, where cooling is implicite. Will be interesting to see how they behave in a simulator. You’ll need a strong power supply probably with these.
Thank you so much for your reply and the update!
So good to see that there is another person out there with the same crazy ideas.
Just to understand it correctly, you installed a 3rd motor to tilt the harness, right? So the motor is strong enough for that? And it seems like there are two overlapping movements or degrees of freedom of the harness that enables tilting it?
I though that two actuators were needed to lift and lower the two suspension points of the harness (which represents the lift of each side of the glider)
It is also interesting to see that you are missing the pitch movement more than the general feeling of getting lifted (or lowered).
Again, thank you so much for all the info!
The third motor sits right in the middle of the rig, the cord is between the two sides of the rig and the spool on the motor lifts one side and lowers the other one (well, lowering is performed by gravity actually). See this picture:
Due to the two pulleys on top I only require half the force. Also, the central pivot point has the advantage that I do not need to lift my entire weight with the motors.
Further to that I would not say that I miss pitch more than G-forces, but I think it is more prevalent in thermals. Also, I don’t see how I could easily implement the G forces caused by lift since it would require a lot of space and very strong motors ($$$). Pitch is simply a lower hanging fruit. Really important were the roll movements though!
Yet another thing to simulate in combination with VR games is pushing the speedbar. This is pretty simple however (just a multi turn potentiometer) and my sensor PCB is already ready for that. Had no time for the mechanics yet and I do not really miss it.
For pitch I am planning the same concept as for roll, just 90 deg rotated. The motor will sit in the center on top, above the top swivel, which will then be hung below the motor. I still need to measure the required forces though.
Bonjour, je suis étudiant en mécanique général. Je suis amener à réaliser un projet de prototypage avec mon groupe d’étudiant (3 personnes). Nous cherchons à nous tourner vers un projet similaire au votre. Nous aimerions simuler les mouvements de roulis et de tanguage. À notre dispositions, nous avons des enseignants en mécanique, prototypage et technologies. Serai il possible de vous contacter pour échanger sur votre expérience pour nous orienté dans notre projet?
Merci d’avance.
Durand Olivier
0766728100
Bien sur vous pourier contacte mois, mais sil vous plais en anglais. My French is very bad unfortunately. You can ask either here directly or with a private message, as you prefer. Regarding the project as such: Roll simulation is not too difficult, but I am struggling with the pitch simulation which requires much stronger forces. There is a simple equation which says that force is proportional to cost and that sets limits to hobby projects…
Great! Thank you very much for your quick reply.
Our project is only just beginning, but as I mentioned, we have professors who are researchers in the fields of mechanics, electronics, etc. This has already allowed us to discuss with them, and we are currently exploring a way to simulate the pitching motion.
Would it be possible to exchange messages to ask our questions? We are currently in the research phase. We are looking for projects similar to yours in order to draw inspiration and communicate directly with the people involved, so that we do not start completely from scratch but can build on your past experiences.
Regarding resources, we have a budget allocated by the university, which is modest but still significant. In addition, many components are provided to us free of charge by the university. We would like to direct our project more towards the mechanical part related to the structure’s movement, rather than focusing on electronics and control.
Therefore, we would like to concentrate on the mechanical part this year, and handle the receivers and control systems next year, since this is a project that can be carried out over two years. However, we still need to deliver a functional prototype by March.
I hope I have been clear. I apologize, my English is not very good either. Thank you for everything, and have a nice evening.
I am copying my two teammates, Hannah Le-Core and Mathieu Haensch.
Cordialement
Durand Olivier
07 66 72 81 00
Hello Grizzly :slight_smile:
I’m working on a similar project and just saw your project. Cool work!
Could you possibly tell me how you get the force feedback data? Via BLE Gamepad Library for the ESP32? Is there an example or documentation for this (feedback data)? My idea was actually to solve the problem via GliderSim telemetry data and FlyPT-Mover (plugin).
Best regards, Matthias
Yes, essentially I am using a BLE gamepad library, which I combined with mouse and keyboard libs. After all it is all just HID stuff and you find all the bits and pieces on the internet.
Which movements are you planning to support?
I am trying to develop a cable pull system that supports pitch and roll (2 central motors at the top, 3 pivot points on the harness, rear left, rear right, front with pulley). Do you have any more details on how you obtained the feedback data? Do you use the telemetry data (UDP interface in Pro Tools) or do you extract the data from a USBHID force feedback report somehow?
Last year, I already created joystick controls for the brakes and speed (ESP32/AS5600/cable starter - retraction). I would also like to build brakes with feedback later on if my system works…
Your setup sounds pretty much like what I do for roll and pitch. With pitch I am not yet quite there, it requires a huge amount of power. I started with two motors for the breaks which simulate realistic forces and allow me to sense the break position relativ to the point where the wing responds with 20N force. It also allows me to simulate turbulences and serves as a training device for active flying (that was my initial goal, Glidersim etc. came later). Roll simulation made it all a lot more realistic. Regarding the telemetry data, I convert them to HID force feedback data on the PC side and send them to my simulated HID gamepad on the ESP32, but be warned, interpretation of these data is … difficult. For more details regarding Glidersim etc., we should change to direct messages, since this is not at all related to SimpleFoc, unless there are really more people interested, which I doubt a bit, we are a rare species :grinning_face: .
