Hi all,
Here is my first test of this great library. Open loop mode with ESP32 and a quite big Gimbal BLDC 24 poles motor.
See the result here :
As you can see I feed the motor with 2A 12V
code is a merge of examples from the lib :
* ESP32 open loop control example sensorless
float target_velocity = 0; // rad/s
// Motor instance
// BLDCMotor( pin_pwmA, pin_pwmB, pin_pwmC, pole_pairs, enable (optional))
BLDCMotor motor = BLDCMotor(25, 26, 27, 12);
// power supply voltage
// default 12V
motor.voltage_power_supply = 12;
motor.controller = ControlType::velocity_openloop;
// contoller configuration
motor.voltage_limit = 7;
motor.velocity_limit = 50;
Serial.println("Set the target velocity using serial terminal:");
// receive the used commands from serial
serialReceiveUserCommand();
static String received_chars;
while (Serial.available()) {
// get the new byte:
received_chars += inChar;
// end of user input
if (inChar == '\n') {
// change the motor target
target_velocity = received_chars.toFloat();
Serial.print("Target velocity ");
// reset the command buffer
received_chars = "";
It works really well, but as it is in open loop the motor ends by loosing the sync and stalls.
I can’t bear waiting for my magnetic sensor to come from China…
I would be really interested in helping if current sensing mode would be developped.
Thanks for all teh efforts done in this lib
JP
