New project: Learning SimpleFOC and building an axial-flux PCB motor
Hi guys!
Just wanted to introduce myself as I’m brand new to the community and about to embark on a bit of a learning adventure.
I’ve got a project in mind that I’m really excited about, but before jumping in, I want to take the time to understand the fundamentals and get to grips with the technology.
I plan to keep this thread updated as I progress, documenting what I’m learning, the decisions I make, the things that work, and (no doubt) the things that don’t!
I’m hoping to benefit from the experience of those who’ve already travelled this road. Please feel free to throw in suggestions, point me towards useful resources, or tell me when I’m heading down the wrong path.
My intention isn’t just to take information from the community. I’d like to make this an ongoing project that others can follow, learn from and hopefully contribute to. As I get further along, I’ll share designs, code, test results and lessons learned so that I can give something back as well.
The goal
Build a small, battery-powered axial-flux brushless permanent-magnet (BLPM) motor that doubles as a demonstration flywheel.
Initial performance targets:
  • Speed: 3,500 RPM
  • Runtime: At least 15 minutes
  • Motor power: Approximately 20 W continuous
  • Power source: Two 18650 lithium-ion cells (2S1P)
Initial project setup
  • Motor architecture: Axial-flux permanent-magnet motor.
  • Stator: Air-core design using copper windings fabricated directly onto a PCB.
  • Rotor: Permanent magnets, with the rotor assembly also serving as the flywheel.
  • Motor control: Exploring SimpleFOC as the control software.
  • Controller: Arduino-compatible microcontroller, with STM32 and other options to be investigated.
  • Power electronics: Three-phase MOSFET inverter and associated gate-driver circuitry.
  • Position feedback: Magnetic rotary encoder.
  • Current sensing: Phase-current measurement for FOC.
  • Electronics: Ultimately aiming for a single custom PCB integrating the motor controller, sensing and power electronics, rather than a collection of separate boards.
  • Power management: Rechargeable 2S lithium-ion battery system, including charging and battery protection.
Where I’m starting
I’m deliberately starting with the learning phase rather than rushing into component selection and construction.
SimpleFOC looks like a great starting point because it’s open source, has an established community and provides a framework we can build upon rather than reinventing everything.
There’s plenty I need to learn about FOC, motor characteristics, current sensing, encoders, gate drivers and the practicalities of designing the electronics.
Once I’ve got through that initial learning curve, the really interesting part begins: designing the PCB, building the motor, getting it spinning and seeing how it performs!
I’m looking forward to sharing the journey and hopefully getting to know some of you along the way.
Thanks in advance to everyone willing to offer a little guidance. I’m excited to get started!
regarding the speed: is 3500RPM NolLoad or recommended speed? If it's recommended speed, than better aim your kV for around 6000-7000RPM with your "windings" Don't use too many poles, otherwise simpleFOC might struggle reaching 600+ rad/s
1 Answer
1
Very interesting project :slight_smile:
