Hi, I am running a project with a iFlight GM6208 equipped with a AS5048A (using the SPI bus). As controller I am using at the moment a ST G431RB (the plan is to switch to this board later). I am quite happy with the results: I’d like to improve the system by increasing the accuracy of the sensor (the current one shows a deviation fluctuating around 0.3/0.5degrees). The MT6835 seems promising but I would like some feedback about people that have used it: what is the precision that you guys experience (of course the resolution is namely much better than the AS5048A but I wonder about the “actual” noise), has the calibration process suggested in the datasheet (the second one which consists in driving the motor at constant speed) helped, are there any reliable sellers (the major sellers seem on AliExpress)?
Thanks
My CNC’s DRO gives stable micrometer position on 4mm ballscrew, so sensor noise is better than ±0.05°. Probably much better, but I don’t think I ever checked exactly what it was since I only have 14-bit sensors for the other axes (their readings fluctuate by a micrometer or two).
It does have significant nonlinearity throughout the rotation (±0.5° according to the datasheet), so try CalibratedSensor with LUT size 168 (the number of cogging steps for your motor). But I would change this line to n_pos = 6
I don’t know why 5 was chosen there. 4 would make sense for steppers and 6 for BLDC since those are their natural step sizes which should give the most evenly spaced stopping positions. 5 will give inferior positioning on both.
I haven’t tried MT6835’s built-in calibration. I expect its effectiveness will depend on the smoothness of the motor’s open loop rotation, which is often not good at low speed, but is assisted by inertia at higher speed, and a gimbal motor should be smoother than most. The SimpleFOC calibration methods depend on evenness of its open loop stepping positions. Both methods are worth a try. In my case, I was able to judge the linearity by how much my NEMA23’s velocity varies throughout the revolution, since it’s super sensitive to any variation in electrical angle. Not sure how to judge it on a BLDC.
I can’t find my notes (if I took any), but I think I was getting better than ±0.05° position holding using angle_nocascade and voltage control mode. Regular angle mode adds a small delay in response to disturbance, and foc_current adds another small delay, so that may have been as much as ±0.5° or something if I really harrassed it. I’ll try it again once I get my stepstick’s firmware finished so I can just plug it into the GRBL board rather than redoing all the electronics (which ended in failure when I tried before, so I’m currently only using the sensors for position display, not closed-loop control).
Thanks for the feedback. Has anyone tested encoders (not necessarily magnetic) that reach a resolution of 0.01 degrees? Thanks
Ok, I’ve done some real testing now. With hysteresis 0°, each of the 7 bandwidth settings gives this many units of variation while holding still:
0: Usually 5, max 7
1: Usually 7, max 9
2: Usually 9, max 11
3: Usually 11, max 15
4: Usually 16, max 21
5: Usually 22, max 29
6: Usually 31, max 43
7: Usually 40, max 55
So bandwidth 7 is 100% reliable to 15 bits, 5 is reliable to 16 bits, 3 is reliable to 17 bits, 0 is reliable to 18 bits.
My CNC has 12V power, NEMA23 steppers, SFU1204 ballscrews, TorqueControlType::voltage, MotionControlType::angle_nocascade, P=75, I=10000, D=0 (yes those values are crazy high, but work well with nocascade), loop time 60µs on SimpleFOC Stepstick (STM32G431 and MAX22213). The screws have hand cranks so it can also be operated manually. Position holding with bandwidth 6 is ±3µm while harassing it, which is ±0.27°. Bandwidth 3 and lower mostly hold ±2µm, but I did see 3 briefly on all of them. The hysteresis setting makes little difference. For comparison, the 14-bit AS4057P holds ±4µm, so ±0.36°.
Bandwidth does make a big difference at high speed. Below 3, the motor’s top speed is much slower due to the angle lagging (these motors are super sensitive to any angle offset).
I wonder if and how the lookup tables for atan2, sin, cos calculations play a part in that scenario?
You can have a super precise sensor, but the calculation-accuracy will hit a wall eventually.
I’m sure in UNO world these lookup tables were the bees-knees to make FOC run at decent speed, but now many FPU equipped MCUs run much faster and they might want to use the real thing, especially if it would improve accuracy significantly. ( e.g. looptime with rp2350 is around 30-40kHz, so a few more clocks spend on accuracy won’t hurt)
edit: BigBrother answered that question already. The fast atan2 routine only matters during initFOC, the high-resolution sensor can shine afterwards.
(It’s a bit different, when using smoothingSensor, but that’s not the subject here)
That was an issue with the original 200 entry float lookup table, but the interpolated lookup we have now is very good. And I’m using STM32’s CORDIC sin/cos anyway, although I think the difference in precision and speed is negligible. For LinearHall, it would probably be best to use CORDIC for atan2 and lookup for sin/cos. It wastes some cycles to switch CORDIC between the two every frame, and atan2 has more to gain.
I tried getting my loop time to <40µs (using faster SPI clock and asynchronous transmission) so it can update on every PWM cycle to see if I could increase the holding accuracy any further, and the answer is: not much, if any.
But it is incredibly good when holding still undisturbed. Plotting the calibrated encoder reading rather than the DRO micrometers, it it holds within one step of the 16-bit reading I’m using, which is 0.0055°.
I tested with 18-bit reading (using slowest bandwidth and no hysteresis), and it still holds within one step, or better since the percent of time spent at each of the two steps changes proportionally as you advance the target in extremely small increments.
Not that such precision actually means much without a way to calibrate the nonlinearity to that precision as well. I only have the accuracy of open loop stepping, which is probably around ±0.05°. But since I want to make a SCARA pick-and-place machine, and that only needs high precision while holding still, it should be excellent when sufficiently calibrated.
Here is the asynchronous SPI code for STM32G431, if anyone is interested. It also saves about 10 microseconds of unnecessarily reconfiguring the SPI every call.
void SPIAngleStart() {
HAL_SPI_Init(SPI.getHandle());
digitalWrite(SPI1_NSS, 0);
__HAL_SPI_ENABLE(SPI.getHandle());
u8 data[4] = { (MT6835_OP_ANGLE<<4), MT6835_REG_ANGLE1, 0, 0 };
for(int i = 0; i < 4; i++) *(volatile u8*)&SPI1->DR = data[i];
void SPIAngleFinish() {
u8 data[4];
for(int i = 0; i < 4; i++) { while(!(SPI1->SR&SPI_SR_RXNE)); data[i] = *(volatile u8*)&SPI1->DR; }
spiAngle = ((u16)data[2]<<8)|data[3];
digitalWrite(SPI1_NSS, 1);
That only reads the upper 16 bits of the angle. The RX FIFO is only 4 bytes and contains two duds corresponding to the first two writes, so to get the third angle byte, you need to read at least one of the duds before writing another zero to DR to initiate the transfer.
