CONTROLLER: NUCLEO64-G431
DRIVER: DRV8302
SENSOR: MT6701
MOTOR: RS2205
ALGO: SimpleFOC, voltage mode
Hi, I’m was trying to interface the MT6701 SSI inerface and was facing an issue with getting weird values for angle.
I tracked the issue down to the line below:
{MagneticSensorMT6701SSI.h}
#if defined(TARGET_RP2040)||defined(ESP_H)||defined(CORE_TEENSY)
#define MT6701_DATA_POS 1
#else
#define MT6701_DATA_POS 2
#endif
Making this shift value “1” rather than 2 completely solved the issue. Why is there a platform-based decision here? From everything I can read (and see) only one shift should be needed???
