Motor only operates at 3 distinct speeds with TorqueControlType::foc_current
Hi guys, I have been following the getting started guide and am now on the last step which is this:
I have changed the motor.torque_controller variable to TorqueControlType::foc_current and set the motor.controller variable to MotionControlType::torque
I have a ~20R phase winding resistance and 24V supply.
I am finding that my motor only seems to have 3 discrete speeds. If I type MTX where 0 <= X < 1.0 it goes one fixed rotational speed, then if 1.0 <= X < 2.0 it goes faster at a single rotation speed, and finally for X >= 2.0 it goes fastest.
There is no smooth increase in speed as I would expect. So what is going wrong?
My code is simply as below, very similar to the example:
BLDCDriver3PWM driver = BLDCDriver3PWM(4, 5, 6, 7);
MagneticSensorSPI sensor = MagneticSensorSPI(19, 14, 0x3FFF);
SPIClass SPI_AS5047P;
// ACS712-05B has the resolution of 0.185mV per Amp
InlineCurrentSense current_sense = InlineCurrentSense(185.0f, 1, 2, _NC);
float target_position = 0.0;
void doMotor(char* cmd) {
  command.motor(&motor, cmd);
  // Wait for something to be typed at the other end of the serial connection (there is no other way to detect a serial port ready to go).
  while (!Serial.available()) yield();
  // void begin(int8_t sck = -1, int8_t miso = -1, int8_t mosi = -1, int8_t ss = -1);
  SPI_AS5047P.begin(47, 20, 21, 19);
  // spi mode (phase/polarity of read/writes) i.e one of SPI_MODE0 | SPI_MODE1 (default) | SPI_MODE2 | SPI_MODE3
  sensor.spi_mode = SPI_MODE1;
  // speed of the SPI clock signal - default 1MHz - AS5047P can do up to 10MHz
  sensor.clock_speed = 1000000;
  sensor.init(&SPI_AS5047P);
  driver.voltage_limit = 12;
  if (!driver.init()) {
    return;
  // link driver
  // link driver to cs
  // current sense init
  if (!current_sense.init()) {
    Serial.println("Current sense init failed!");
    return;
  motor.monitor_downsample = 1000;                      // set downsampling can be even more > 100
  motor.monitor_variables = _MON_CURR_Q | _MON_CURR_D;  // set monitoring of d and q currents
  // initialise motor
  if (!motor.init()) {
    return;
  if (!motor.initFOC()) {
    Serial.println("FOC init failed!");
    return;
  motor.target = 1.0;
  command.add('M', doMotor, "Motor");
  Serial.println(F("Set the target using serial terminal and command M:"));
  // iterative function setting the outer loop target
  // display the currents
Thanks for looking.
