Sure… Here is the example code I am using. I am also attaching the AS5048A code I have used for testing and its output.
Hardware Setup - I am using a basecam BGC board which uses the ATmega328P microcontroller. The spi lines of the basecam are connected with the AS5048A.
To make the motor move, I type the command - T 200 in the terminal
* Position/angle motion control example
* Steps:
* 1) Configure the motor and magnetic sensor
* 2) Run the code
* 3) Set the target angle (in radians) from serial terminal
#include <SPI.h>
// Define the chip select pin
const int CSPin = A4;
// SPI settings for AS5048A
SPISettings AS5048ASettings(1000000, MSBFIRST, SPI_MODE1);
// magnetic sensor instance - SPI (config, chip select pin)
MagneticSensorSPI sensor = MagneticSensorSPI(AS5048_SPI, CSPin);
//MagneticSensorI2C sensor = MagneticSensorI2C(AS5600_I2C);
BLDCDriver3PWM driver = BLDCDriver3PWM(3, 5, 6);
// angle set point variable
float target_angle = 50;
// contoller configuration
motor.PID_velocity.P = 4.0f;
motor.PID_velocity.I = 20;
motor.PID_velocity.D = 3;
motor.voltage_limit = 6;
// angle P controller
motor.P_angle.P = 20;
motor.velocity_limit = 20;
// align sensor and start FOC
// Arduino UNO loop ~1kHz
// Bluepill loop ~10kHz
motor.move(target_angle);
// motor.monitor();
The output for my code is -
MOT: Monitor enabled!
MOT: Init
MOT: Enable driver.
MOT: Align sensor.
MOT: Init FOC failed.
Motor ready.
Warn: \r detected!
200.000
The Code which works for my AS5048A is -
#include <SPI.h>
uint16_t readAS5048A() {
uint16_t angle = 0;
// Start SPI transaction
SPI.beginTransaction(AS5048ASettings);
// Pull CS low to select sensor
digitalWrite(CSPin, LOW);
// Send read command (0xFFFF)
SPI.transfer16(0xFFFF);
// Pull CS high
digitalWrite(CSPin, HIGH);
delayMicroseconds(50);
// Pull CS low again to read data
// Read the angle data
angle = SPI.transfer16(0xFFFF);
delay(10);
// Pull CS high
// End SPI transaction
SPI.endTransaction();
// Mask to get only 14-bit data (remove parity and error flag bits)
angle = angle & 0x3FFF;
return angle;
Serial.println(“AS5048A Angle Reader - SPI”);
delay(100);
// Set the chip select pin as output
pinMode(CSPin, OUTPUT);
delay(500);
// Begin SPI communication
SPI.begin();
// Read angle from AS5048A
uint16_t rawAngle = readAS5048A();
// Convert to degrees (14-bit resolution)
float angleDegrees = (float)rawAngle * 360.0 / 16384.0;
Serial.print("Raw: "); Serial.print(rawAngle);
Serial.print(" | Angle: "); Serial.print(angleDegrees, 2); Serial.println(“°”);
delay(100);
And the output for this encoder read is -
Raw: 7484 | Angle: 164.44°
Raw: 7482 | Angle: 164.40°
Raw: 7481 | Angle: 164.38°
Raw: 7486 | Angle: 164.49°
Raw: 7478 | Angle: 164.31°
Raw: 7480 | Angle: 164.36°
