MOT: Failed to notice movement , MOT: Init FOC failed
Hi community
I’m facing a “failed to notice movement” issue reflected in Serial terminal. I’ve tried to measure the sensor and use a Testpin (D13) to see if there is any movement from hall inputs during motor init. Yes there were hall signals coming in and have witness the motor shaft rotate couple of “steps” FWD followed by REV. I’m using BLDC. But no subsequent motoring movement due to motor init filed. I’ve also tested successfully on the standalone hall sensors and got a complete 6.28 rad after 1 mechanical revolution turn of shaft . please help me if there are other things to explore. How many pulses of hall to be expected during sensor alignment with motor , my scope capture below, is this sufficient? or what is the expected during alignment? thank you.
So what may be the issue of no movement? Can anybody help. Thank you.
digitalWrite(Testpin,!digitalRead(Testpin));
// align sensor and start FOC
delay(1000);
IN USE: Arduino 1.8.18/ SimpleFOC V2.3.5/ STM32 MCU based Boards V2.3.0/MCU board specific: STM nucleo F401RE/ Driver Board: 250W B6 driver with 6 pwm inputs (all active high).
#include <f401reMap.h>
int Testpin = 13;
// BLDC motor instance
BLDCMotor motor = BLDCMotor(7); //7pp
// BLDC driver instance
BLDCDriver6PWM driver = BLDCDriver6PWM(7, 2, 6, 3, 5, 4); //(7,2, 6,3, 5,4);
// Hall sensor instance
// HallSensor(int hallA, int hallB , int cpr, int index)
// - hallA, hallB, hallC - HallSensor A, B and C pins
// - pp - pole pairs
HallSensor sensor = HallSensor(10, 9, 8, 7);
// channel A and B callbacks
void doA(){sensor.handleA();}
void doB(){sensor.handleB();}
void doC(){sensor.handleC();}
// target voltage to be set to the motor
float target_voltage = 0.8;
//General
pinMode(Testpin,OUTPUT);
// monitoring port
//Sensor
// hardware interrupt enable
Serial.println(“Sensor ready”);
//Driver
driver.pwm_frequency = 20000;
driver.voltage_power_supply = 15;
// daad_zone [0,1] - default 0.02f - 2%
driver.dead_zone = 0.05f;
// driver init
// link driver
//FOC
// aligning voltage
// choose FOC modulation
// set torque mode
motor.torque_controller = TorqueControlType::voltage; //voltage Torque control mode
//Motor
// set rotation first direction
//motor.sensor_direction = Direction::CCW;
delay(1000);
motor.move(target_voltage); //see above
1 Answer
1
Since initFOC failed, decided to define the specific motor.zero_electric_angle = x.xx. (that’s why skip offset Calib reported in serial) It finally works. also changed the PP.
From Serial upstream:
MOT: Init
MOT: Enable driver.
MOT: Align sensor.
MOT: sensor_direction==CW
MOT: PP check: OK!
MOT: Skip offset calib.
MOT: No current sense.
MOT: Ready.
