Dear all
I think I have found a solution for a good and cheep way of making a DIY BLDC, where SimpleFOC would come in very handy.
A MC generator has a decent size (115mm+ OD) and they seem to have quite thick coil wires. Don´t know the amp rating, but I would guess a large MC needs some juice for ignition, lights and so on.
The windings may need to be rewinded or cut and soldered.
You can find a MC stator with windings for around 22$
has anyone tried hacking a MC generator ?
Hmm… A 18slot - 16 magnets has a better winding factor then a 12slot.
Do you think a 3phase 18slot “outrunner” generator stator will be winded and ready to be used for BLDC?
With a custom rotor.
Here is an example. Imagine driving this as a outrunner with whatever magnets you choose.
The mounting hole is probably a standardized pattern, which could be sweet for a DIY BLDC.
Which wire gauge do you think this is ?
https://www.walmart.com/ip/18-Pole-Stator-compatilbe-Hammerhead-250cc-172MM-032000-Baja-Reaction-250-2-seats-Dune-250-Joyner-Sand-Viper-Dirt-Devil-Kinroad-Roketa-GK-06-GK-13-GK/242980002
Actually these Washing Machine stators looks better for 24V. The MC stators would be better suited for rewinding to a higher voltage BLDC. This image is from a Samsung Washing machine.
What’s the name of the website you used to make the wiring configuration, I have been looking for it to rewind a old bldc motor i found
