Hey all,
I am currently working on simpleFOC open-loop velocity control with a throttle and Maxon EC-I 52 48V 440watts with my own built motor driver. I am unable to attain a proper RPM and it gets stuck in middle.
It is a 48v motor but i was able to supply 32v as it is my rps limit.
My driver is IR2184 which operates in 15v.
Below i have attached my code, maxon spec sheet and my motor driver schematics.
If you could give me some guidance on this topic I really appreciate
BLDCMotor motor = BLDCMotor(8);
int motor_speed;
//target variable
float target_velocity ;
pinMode(A0,INPUT);
driver.voltage_power_supply = 48;
driver.voltage_limit = 8;
// limiting motor movements
// motor.voltage_limit = 5; // [V]
// motor.phase_resistance= 25;
// motor.current_limit=2;
// motor.voltage_power_supply = 30;
// open loop control config
// motor.velocity_limit=20;
//motor.voltage_limit=1;
//motor.phase_resistance = 1;
// motor.current_limit=1;
motor.voltage_limit=12;
motor.phase_resistance=1;
// motor.voltage_limit=34;
motor.velocity_limit=100;
// motor.voltage=(1,1);
// init motor hardware
Serial.begin(9600);
Serial.println(“Motor ready!”);
Serial.println(“Set target velocity [rad/s]”);
//target_velocity=15;
// to turn the motor “backwards”, just set a negative target_velocity
motor_speed = map(analogRead(A0)-5, 0, 1023, 0, 100);
Serial.println(motor_speed);
motor.move(motor_speed);
//target_velocity+=2;
Summary
This text will be hidden
