LOL... ChatGPT writing SimpleFOC code
Brave new world.
The last one with the angle sensor in a closed loop is particularly funny.
I’m too busy to test the actual code but it got the basics correctly.
I guess the learning curve to teach chatGPT to do the right thing is much longer than the learning curve to write the simpleFOC code?
It would be cool to have a request template, were the user only has to fill in blanks and then send it to chatGPT.
You can ask directly in github now
// Motor instance
// Motor driver instance
BLDCDriver3PWM driver = BLDCDriver3PWM(PA8, PA9, PA10, PB6);
// Encoder instance
Encoder encoder = Encoder(PA0, PA1, 2048);
    // Motor driver configuration
    driver.voltage_power_supply = 12; // Power supply voltage
    // Encoder configuration
    encoder.init();
    motor.linkSensor(&encoder);
    // Controller configuration
    motor.PID_velocity.P = 0.5;
    motor.PID_velocity.I = 10;
    motor.LPF_velocity.Tf = 0.01;
    motor.P_angle.P = 20;
    motor.velocity_limit = 20;
    motor.voltage_limit = 3;
    // Initialize motor
    // User input for target angle
    static float target_angle = 0;
    if (Serial.available()) {
        target_angle = Serial.parseFloat();
    // Move the motor to target angle
    motor.move(target_angle);
    // Print current angle
    Serial.println(motor.shaft_angle);
