Hey everyone, I am still trying to build an open source energy recovery ventilator (openerv.org). I need quiet motors, with precise RPM control.
I can use the included open loop library example to control the motor’s rpm, as a demo. I got the wiring from this thread, there is none included in the example https://community.simplefoc.com/t/3-bldc-and-stepper-foc-driver-l298n/296/45
But as the video shows, it is very jerky. Any ideas on how I can get smooth motion? It is quiet, though. https://drive.google.com/file/d/1TM7Z1hcQRhO5YeksKZCLbeHRdPiJlpsH/view?usp=sharing
This is the code I used:
BLDCDriver3PWM driver = BLDCDriver3PWM(9, 10, 11);
//target variable
float target_velocity = 0;
pinMode(8,OUTPUT);
digitalWrite(8,LOW);
driver.voltage_limit = 6;
// limiting motor movements
// currnet = resistance*voltage, so try to be well under 1Amp
// open loop control config
// init motor hardware
