How to reset shaft_angle when switching from velocity to angle control?
Hi everyone,as title suggests,I was first in velocity mode, command the motor to spin for some turns.Then I switch the motor to angle mode, target at 0,expected the motor to stay upright,but the motor keeps rotate back until all the previous accumated turns unwind.
Is it possible to reset the shaft_angle or somekind of variable so the motor forgets the accumated turns and go to zero angle immdiately?
Looked through source code many times,tried to change motor.shaft_angle = 0 with command interface but no luck.pls help me with it,thanks.
SimpleFOC tracks the total number of rotations as well as the current angle, and the target value is an absolute angle.
So you can set the target to sensor.getAngle() (or motor.shaft_angle). Then it will keep the current position, but that position won’t be 0.
What you’re asking is to make whatever the current position is after running in velocity mode for some time to be the new zero value.
You can in theory use the parameter motor.sensor_offset for this purpose. You can try setting motor.sensor_offset = sensor.getAngle(). Then setting motor.target=0 should work as expected, I think.
I am not sure if this is intended, but if I do the following:
// In setup()
motor.sensor_offset = 1.15f
// At some point set
motor.target = 0;
// In loop() after rotation to 0 has completed
motorCurrentAngle = sensor.getAngle();
motorCurrentAngle // Expect 0, but is reading 1.15f~
If the offset is given/set, and the motor is set to 0, I would think that then checking the current angle should show 0, no? Otherwise, I don’t quite get the reason for the offset in the first place, if I then have to offset the offset when working with the current angle.
Ok, but what is the output of motor.shaft_angle?
When reading the sensor, you get the actual sensor value. The motor.sensor_offset is a property of the motor, the sensor does not use that.
I will be sure to check that. For some reason I thought motor.shaft_angle would reset back to 0 after a full rotation, but now I can’t remember for sure. I am using a reducer, so I need to keep track angle and I knew sensor.getAngle() didn’t reset. I will try and give that another look this afternoon.
