If I place this in the loop, the angle comes back in 14 bits which means SPI is working well.
Serial.println(sensor.readCorrectedAngle());
Serial Monitor:
9350
9350
9349
9349
9349
@runger Any ideas what might be happening here? Have you ever flashed the Non-volatile memory in the AS5074U? I’m not trying to burn it in permanently, just set it in the setup loop
I recently fixed bugs in the drivers for the AS5047 and AS5047U. I was able to test the AS5047 driver on an AS5047P, and this was working for my test cases.
The AS5047U is unfortunately a bit different in terms of its protocol, hence it has its own driver. I didn’t have a chance to test it yet. So it could be that there are still bugs to be fixed in the driver.
The code looks ok in principle, but you should read the settings first, and change only the value you’re trying to write, like this:
Adding some delays can’t hurt, either. On a fast MCU you could in theory hit the chip too quickly, it likes a bit of delay after operations.
If the above is not working for you, it is probably down to problems with the write implementation and/or CRC calculation…
You could check using the sensor.errorflag and sensor.warningflag fields, and also by calling:
AS5047UError errinfo = clearErrorFlag();
// then check fields of errinfo like errinfo.crc_error ...
if (errinfo.crc_error) Serial.prinltln("CRC Error");
I’m really sorry - I will have to debug it.
It will take me a little while, as I have a lot of other work right now.
If you can make progress on it in the meantime, all the better!
Otherwise I have a AS5147U which I can test on - it has the same protocol as the AS5047U as far as I can tell. I will set it up and test it next week if I can find the time.
I really appreciate all the time you’re putting into this regardless, and there’s absolutely no rush. I will keep working on it and post my progress here
