High-Precision Closed-Loop velocity Control
Hi
I am using Simple FOC to control a BLDC motor with an AS5048 magnetic encoder. How can I achieve a speed accuracy of less than 0.5% with only algorithm adjustments, with a rated speed of 60 rpm? What parameters should be mainly adjusted? thanks
