engine pp=2
volts = 24
voltage control
pp check = 2 correct
but the motor does not turn, only the sound is heard, the interruptions are 12 in a full revolution
2 PP is a very low number of pole pairs
With hall sensors, I think you only get 12 counts per revolution, this won’t give you much position accuracy.
If you share your code here, perhaps we can help to see if there are mistakes, but if you get no movement at all then it could also be an electrical problem… kindly share some more details of your setup (which driver, which MCU, maybe some pictures/diagrams of how you have connected things).
* Velocity motion control example
* Steps:
* 1) Configure the motor and sensor
* 2) Run the code
* 3) Set the target velocity (in radians per second) from serial terminal
* NOTE :
* > Specifically for Arduino UNO example code for running velocity motion control using a hall sensor
* > Since Arduino UNO doesn't have enough interrupt pins we have to use software interrupt library PciManager.
* > If running this code with Nucleo or Bluepill or any other board which has more than 2 interrupt pins
* > you can supply doC directly to the sensor.enableInterrupts(doA,doB,doC) and avoid using PciManger
// software interrupt library
BLDCMotor motor = BLDCMotor(2);
// hall sensor instance
HallSensor sensor = HallSensor(2, 3, 4, 2);
// channel A and B callbacks
void doA(){sensor.handleA();}
void doB(){sensor.handleB();}
void doC(){sensor.handleC();}
float target_velocity = 0;
// initialize sensor sensor hardware
// software interrupts
// aligning voltage [V]
// contoller configuration
motor.PID_velocity.P = 0.2f;
motor.PID_velocity.I = 2;
motor.voltage_limit = 12;
// align sensor and start FOC
// Arduino UNO loop ~1kHz
// Bluepill loop ~10kHz
// motor.monitor();
this is the code
mcu card = stm32f411 re
driver card =
FOC-SimpleFOC-MotorDriveDevelopmentBoard
- IR2103 drivers
- 1 engine
- 36V/20A
- low-side current sensing
doing engine recognition
getting offset
but in speed mode the motor makes noise and does not turn.
Your code says
Did you send the velocity command to the motor? If you just run the code it will stand still. You need to change the velocity.
Serial command
Target velocity=2
What’s the resistance of the motor?
You’re using 24V normally, but 1V during alignment. Maybe the currents are too high? You could try setting a lower voltage limit to see if things improve.
Are you working in ArduinoIDE or PlatformIO?
If you check the PWM outputs from the MCU to the IR2103 drivers, do they look correct? You can check them with an oscilloscope or logic analyzer…
Isn’t it supposed to be
T2
Instead of
Target velocity=2
Also you say
But I don’t see you setting this variable anywhere. It’s initialized as 0 at the beginning, then you just pass it directly without modifying it.
I suggest you initialize it with
float target_velocity = 1;
and see what happens.
