G431B_ESC1 Temp and pot reading unavailable when current sensing is enabled
Hi All,
I have a BLDC on a G431B_ESC and I want to switch from using a magnetic sensor AS5600 to using current sensing and need to get the Temperature of the board in all modes.
I have written code that is meant to work after exploring the issues stating
PB14 must be remapped over DMA which I failed at
then tried:
float temp = _readADCVoltageInline(A_TEMPERATURE, currentSense.params);
both approaches return a negative constant value of -30.53
Here is my code:
#define CURRENT_SENSING_ENABLE 0
// Motor instance
BLDCMotor motor = BLDCMotor(11, 0.1, 270, 0.00002);
#if CURRENT_SENSING_ENABLE == 1
LowsideCurrentSense currentSense = LowsideCurrentSense(0.003f, -64.0f / 7.0f, A_OP1_OUT, A_OP2_OUT, A_OP3_OUT);
#endif
// Magnetic sensor instance
// angle set point variable
float target_angle = 0;
void onMotor(char *cmd) { command.motor(&motor, cmd); }
void doTarget(char *cmd) { command.scalar(&target_angle, cmd); }
void setup()
  Serial.begin(230400);
  /////// Current sensing /////////
  currentSense.init();
  // no need for aligning
#endif
  /////// END Current sensing /////////
  // contoller configuration
  motor.PID_velocity.P = 0.2f;
  motor.PID_velocity.I = 20;
  motor.voltage_limit = 1.5;
  // angle P controller
  motor.P_angle.P = 20;
  motor.velocity_limit = 5;
  // setup sensor config and start FOC
  motor.sensor_direction = CW;
  motor.zero_electric_angle = 3.06;
  // Add commander functions
  command.add('A', onMotor, "motor");
  // command.add('M', setControlMode, "control mode");
  Serial.println(F("Set the target angle in degrees using serial terminal:"));
  Serial.println("Setup...");
  delay(1000); // Delay for 1 second
void loop()
#if CURRENT_SENSING_ENABLE == 0
  float temp = analogRead(A_TEMPERATURE); // Read temperature sensor
#endif
#endif
  float temperature = (1000. / 19.) * (3.3 / 1023.) * temp - 30.5263; // 10bit // @25degree Celcius V=1.055 // (0,-48.6842)(1023,125)
  Serial.print("Temperature: ");
  Serial.println(temperature);
  motor.move((target_angle * _2PI / 360));
Platformio.ini:
[env:disco_b_g431b_esc1]
platform = ststm32
board = disco_b_g431b_esc1
framework = arduino
lib_archive = false
monitor_speed = 230400
lib_deps =
    askuric/Simple FOC@^2.3.4
build_flags =
    -D HAL_OPAMP_MODULE_ENABLED
Any help would be greatly appreciated.
Thanks,
Rafik
You need _readADCVoltageLowSide, not inline.
Hi @dekutree64
Thank you so much for pointing me in the right direction !
The posts I read were pre G431B_ESC1 moving to lowside hence why the error.
I did also find out that the raw value to temperature formula needs to change as the values are not the same as per below
#endif
  float temp = _readADCVoltageLowSide(A_TEMPERATURE, currentSense.params);
  float temperature = (1000.0 / 19.0) * temp - 30.5263;
#endif
Many thanks for your help,
Rafik
For the sake of completeness I am posting the more elegant solution to work around the temperature reading when currentSense is enabled (hopefully will save others the headache):
bool isCurrentSensingEnabled(BLDCMotor &motor)
  return motor.current_sense != nullptr;
float tempSense()
  float temperature;
  if (isCurrentSensingEnabled(motor))
    float rawTemp = _readADCVoltageLowSide(A_TEMPERATURE, currentSense.params);
    temperature = (1000.0 / 19.0) * rawTemp - 30.5263;
  else
    float rawTemp = analogRead(A_TEMPERATURE);
    temperature = (1000. / 19.) * (3.3 / 1023.) * rawTemp - 30.5263; // 10bit // @25degree Celcius V=1.055 // (0,-48.6842)(1023,125)
  return temperature;
