I’m having trouble getting my 2208 gimbal motor to move at all. I have an ESP32 connected to the SimpleFOC Shield.
I have buzzed through these pins directly from ESP32 to the DRV8313 chip on the shield for sanity checking:
VM - measures 24v
V3P3 - measures 3.3v
EN1/EN2/EN3 - all buzz through to GP7 on ESP32
INA/INB/INC - buzz correctly to GP4/GP5/GP6
Motor resistance between phases - 19.5R to 20.5R when measured between pins of the 3 pin terminal block (i.e. motor is connected)
The only thing I haven’t done is buzz through the motor connections from DRV8313 to motor because I assume the SimpleFOC Shield has the layout correct for connecting the DRV8313 to the 3 pin terminal block.
Estimated PP : 2147483647
PP = Electrical angle / Encoder angle
1080.00/0.00 = inf
PP number very high, possible error.
MOT: Align sensor.
MOT: Init FOC failed.
What other debugging can I do to work out why the motor is not moving? Thanks.
Update: here is my Arduino sketch showing just the modified section of find_pole_pairs_number with my own pin numbers:
// BLDC motor instance
// its important to put pole pairs number as 1!!!
BLDCDriver3PWM driver = BLDCDriver3PWM(4, 5, 6, 7);
// Stepper motor instance
//StepperMotor motor = StepperMotor(1);
MagneticSensorSPI sensor = MagneticSensorSPI(19, 14, 0x3FFF);
// magnetic sensor instance - I2C
//MagneticSensorI2C sensor = MagneticSensorI2C(0x36, 12, 0X0C, 4);
// power supply voltage
// default 12V
// initialize motor hardware
// pole pairs calculation routine
Serial.println("Pole pairs (PP) estimator");
Serial.println("-\n");
float pp_search_voltage = 12; // maximum power_supply_voltage/2
float pp_search_angle = 6*_PI; // search electrical angle to turn
