I tried to upload simple foc open loop velocity example code to ESP32 D1 R32. but i got the above error. Pl guide for further process
Hey, esp IDF 3.0.0 is not yet supported in SimpleFOC. An upcoming release will support it…
Then Which version will be working with ESP32?
Please use the 2.0.17 version of the board package for compatibility with SimpleFOC 2.3.3.
We will release a new version in the next weeks that is compatible with 3.0.0 espressif IDF.
Sorry for the inconvenience!
Ok Thanks for your reply. I will try and update you
I M trying simplefoc Balancer . That Google play app GIBALO Not found in Play store. Any other app available for bluetooth connection?
Now Gibalo has downloaded. But In that Balancer, One encoder AMT103 A & B Input has taken and another encoder B& I input Taken . may I know the reason
I was using B and I channels on one of the shields because there was no available hardware configuration for the channel A that would have worked.
So I configured the channel B on the shield as A and I as B.
Bare in mind that this is just semantics, the shied pin names are not important or used in the code.
ok. Thanks for your support.
Hi My setup not running. I connected as it is same as your configuration.Can u send image of front & back of simple foc shield V2.0.4 Board?
Need to verify the jumper.In video, Its not clear to see.
