Hi All,
I am utilizing a custom board to drive a small BLDC motor with just two current sense lines at A and B.
When using the InlineCurrentSense example I get consistent values at A and B, 0 as expected at C.
When I run the CurrentControl example I get stuck at ErrB as in the subject.
Exploring the code, I notice that this error is thrown inside an if statement, in the case both pins B and C are set.
So I wonder why I get there, since I have not pic C for current sensing, and how to fix the issue.
Many thanks in advance,
Marco
Hey @marcosartore,
Sorry for the delay in answering.
So this message is there to say that when you were applying the voltage to the phase B, the code was not able to identify which one août of the pins B or C is the one measuring the current. I do agree that the off statement is problematic here and this is a bug in the code.
But the problem is real, in your case the current B was not measured.
Which phases are you measuring on the hardware?
Could you show us your code also. It would help.
Also, you can skip the alignment procedure completely if you don’t need it.
Set the current_sense.skip_align=true; before the motor.initFOC().
Thanks Antun for your answer.
Actually I am trying, step by step, to create code for a full-featured FOC control of my motor, as in this picture:
I first successfully read the currents in A and B using this code:
// current sensor
// shunt resistor value
// gain value
// pins phase A,B, (C optional)
InlineCurrentSense current_sense = InlineCurrentSense(0.015f, 100.0f, A0, A2);
int triggerPinA = 4;
int triggerPinB = 8;
void setup()
pinMode(triggerPinA, OUTPUT);
digitalWrite(triggerPinA, LOW);
pinMode(triggerPinB, OUTPUT);
digitalWrite(triggerPinB, LOW);
if(!current_sense.init()){
Serial.println("Current sense init failed.");
return;
// for SimpleFOCShield v2.01/v2.0.2
// current_sense.gain_b *= -1; ????
Serial.println("Current sense ready.");
void loop()
PhaseCurrent_s currents = current_sense.getPhaseCurrents();
float current_magnitude = current_sense.getDCCurrent();
Serial.print(currents.a*1000); // milli Amps
Serial.print("\t");
Serial.print(currents.b*1000); // milli Amps
Serial.print("\t");
Serial.print(currents.c*1000); // milli Amps
Serial.print("\t");
Serial.println(current_magnitude*1000); // milli Amps
Serial.println("");
delay(50);
Then tried the current control but I got stuck in the ErrB mentioned problem using this code:
BLDCDriver3PWM driver = BLDCDriver3PWM(4, 8, 12, 22);
#define SENSOR1_CS 42
MagneticSensorSPI sensor = MagneticSensorSPI(AS5147_SPI, SENSOR1_CS);
// current sensor
InlineCurrentSense current_sense = InlineCurrentSense(0.015f, 100.0f, A0, A2, NOT_SET);
// current set point variable
float target_current = 0;
void doTarget(char* cmd) { command.scalar(&target_current, cmd); }
void setup()
// *************** ADDED
driver.voltage_limit = 12;
// ************** VERY IMPORTANT command, missing in the original
// link driver
current_sense.init();
// set torque mode:
// TorqueControlType::dc_current
// TorqueControlType::voltage
// TorqueControlType::foc_current
// foc currnet control parameters (Arduino UNO/Mega)
//motor.PID_current_q.P = 5;
//motor.PID_current_q.I= 300;
//motor.PID_current_d.P= 5;
//motor.PID_current_d.I = 300;
//motor.LPF_current_q.Tf = 0.01f;
//motor.LPF_current_d.Tf = 0.01f;
// foc currnet control parameters (stm/esp/due/teensy)
motor.PID_current_q.P = 1;
motor.PID_current_q.I= 100;
motor.PID_current_d.P= 1;
motor.PID_current_d.I = 100;
motor.LPF_current_q.Tf = 0.002f;
motor.LPF_current_d.Tf = 0.002f;
// align sensor and start FOC
command.add('T', doTarget, "target current"); // T0.2 is a GOOD VALUE for RS motor
Serial.println(F("Set the target current using serial terminal:"));
// Arduino UNO loop ~1kHz
// Bluepill loop ~10kHz
// velocity, position or torque (defined in motor.controller)
motor.move(target_current);
Thanks a lot,
Marco
