Sadly, I think that was a wasted effort
From my measurements between the hall pads and CPU’s VDD pin, ESC1 has 11.8K pullups onboard. And the hall sensors never output 5V, so there’s no danger of damaging the CPU. They do need 5V supply, but the output is either ground or floating, which is then pulled up to the 3.3V CPU voltage via the resistors.
All part of the exploratory process! :). It is not waste effort, esp when you tell others so they don’t have to check next time
