Hey guys!
I am pretty new to the FOC and I have a small problem with my motor control.
In my project I am using an ESP32, a Thrustmaster steering wheel and an arduino. My goal is to control the speed of the motor with the pedals of the steering wheel. This works already but my problem is, that when I step on the gas pedal really quickly the current increases more than it should. Is there any solution for this problem?
#include <Wire.h>
int U_EN = 18; // inhu
int V_EN = 5; // inhv
int W_EN = 17; // inhw
float target_velocity = 12.54;
int gas = 0;
int bremse = 0;
int lenkung = 0;
int turn = 0;
// Motor instance
// driver instance
BLDCDriver3PWM driver = BLDCDriver3PWM(16, 4, 32);
HallSensor sensor = HallSensor(25, 26, 27, 11);
// channel A, B and C callbacks
void doA(){sensor.handleA();}
void doB(){sensor.handleB();}
void doC(){sensor.handleC();}
void receiveData(int byteCount){
gas = Wire.read();
bremse = Wire.read();
lenkung = Wire.read();
turn = Wire.read();
if (turn == 1){
gas = gas \* (-1);}
pinMode(U_EN, OUTPUT);
pinMode(V_EN, OUTPUT);
pinMode(W_EN, OUTPUT);
digitalWrite(U_EN, HIGH);
digitalWrite(V_EN, HIGH);
digitalWrite(W_EN, HIGH);
//I2C
Wire.begin(8);
Wire.onReceive(receiveData);
// initialize sensor hardware
// hardware interrupt enable
// link the motor and the sensor
// driver init
if(!driver.init()){
Serial.println("Driver init failed!"); return;}
// link driver
// aligning voltage [V]
motor.voltage_sensor_align = 0.5f;
motor.PID_velocity.P = 0.1f;
motor.PID_velocity.I = 1;
motor.voltage_limit = 12;
motor.PID_velocity.output_ramp = 30;
// align sensor and start FOC
command.add(‘T’, doTarget, “target voltage”);
Serial.println(F(“Set the target velocity using serial terminal:”));
motor.move(gas);
This is the code I am currently running. The value for motor.move is between 0-100.
Kind regards
Leon
