Contradiction between documentation and source code regarding Kv rating unit
On page Units in the library | Arduino-FOC, the doc states that the unit for motor Kv ratings is RAD/s/V or radians per second per Volt
In the code (constructor for BLDCMotor, Arduino-FOC/src/BLDCMotor.cpp at fb0be07488ed26db7cbc16dff0ef43c30bda818c · simplefoc/Arduino-FOC · GitHub), it says that the unit is rpm/V. Which is not the same (about a factor 10 difference if I get it right).
Which is correct? Should the documentation or the code be adjusted?
Hey!
Yeah, youre right. The real units are rpm/V.
The docs need to be updated! :slight_smile:
Prepared a pull request: Updated unit for KV rating to match code by jwxde · Pull Request #39 · simplefoc/simplefoc.github.io · GitHub
