Compile error please help
Hi Community,
i m using visual studio code with platformino with arduino
i m trying to compile SimpleFoc examples named HMBGC
i install simplefoc library and Pcimanager library
But i m getting that errors , i couldnt solve it.
src\main.cpp:33:43: error: invalid conversion from ‘void ()()’ to 'void ()(byte) {aka void (*)(unsigned char)}’ [-fpermissive]
*** [.pio\build\mkrwifi1010\src\main.cpp.o] Error 1
Can you please help?
Regards
Hey Boris,
Can you show us your platrofmio.ini file?
And your main.cpp file?
Hi
thanks for quick reply
i deleted lib_archive = false from platrofmio.ini file
Now its working :))
By the way is it correct method?
Yep, It is very important to include this in your ini file :smiley:
That s my ini file
[env:uno]
platform = atmelavr
board = uno
framework = arduino
lib_deps =
    askuric/Simple FOC@^2.2.1
    prampec/PciManager@^2.1.4
Dear @Borris123 ,
When using PlatformIO, you currently need to use the option
lib_archive = false
in your platformio.ini
Are you saying it does not compile when using this option?
Hi
Yes if i use lib_archive = false
it doesnt compile
Regards
This part confuses me… are you building for MKR1010 Wifi or for Uno?
Those boards use different platform cores, the MKR1010 is a SAMD21 based board, the Uno is atmelavr.
I did a quick test project for Arduino UNO, and the following compiled for me with no problems, including the option lib_archive = false
Dependency Graph
|-- <PciManager> 2.1.4
|-- <Simple FOC> 2.2.1
|   |-- <Wire> 1.0
|   |-- <SPI> 1.0
So my conclusion is there is something somehow wrong with your setup. Perhaps it will help if you upgrade PlatformIO, upgrade all your platforms and frameworks, and then maybe re-create the project from scratch.
Because at the moment it looks like something is mixed up.
Thank you, i will try again
