Compile error Arduino Mega 2560 with Encoder example
I get a compile error when I compile the Encoder example with an Arduino Mega 2560 board Arduino-FOC/examples/utils/sensor_test/encoder/encoder_example/ I’m on version Simple Foc version 2.2.2.
It says:
/...../Arduino/libraries/Simple_FOC/src/drivers/hardware_specific/atmega2560_mcu.cpp: In function 'void* _configure6PWM(long int, float, int, int, int, int, int, int)':
/...../Arduino/libraries/Simple_FOC/src/drivers/hardware_specific/atmega2560_mcu.cpp:149:22: error: expected primary-expression before ',' token
     .pins = { pinA_h,, pinA_l, pinB_h, pinB_l, pinC_h, pinC_l },
/..../Arduino/libraries/Simple_FOC/src/drivers/hardware_specific/atmega2560_mcu.cpp:151:6: error: request for member 'dead_zone' in 'pwm_frequency', which is of non-class type 'long int'
     .dead_zone = dead_zone
/..../Arduino/libraries/Simple_FOC/src/drivers/hardware_specific/atmega2560_mcu.cpp:152:3: error: could not convert '{{pinA_h, <expression error>, pinA_l, pinB_h, pinB_l, pinC_h, pinC_l}, <expression error>}' from '<brace-enclosed initializer list>' to 'GenericDriverParams'
Compilation error: exit status 1
What is wrong? Compiled with an Arduino Uno gives no problems.
Regards
this is our fault unfortunately.
It is a bug that we’ve introduced recently and we’ll fix it asap.
The fix is to add comma behind the
And remove one the double commas in the line above.
Line 149 and 151 in the file
If you’re using windows it will be in /Documents/Arudino/libraries/Simple_FOC/sec/drivers/…
Thx, that did the tric. In row150 a comma is also missing:
.pwm_frequency = pwm_frequency,
