Does anyone have full code to run drv8302 with esp32 on platformIO, I’m a novice trying to run the drv8302 3pwm code on platformIO, It compiles on arduino IDE but I’m getting
‘MCPWM_SELECT_SYNC_INT0’ was not declared in this scope
identifier “MCPWM_SELECT_SYNC_INT0” is undefined
‘serialReceiveUserCommand’ was not declared in this scope
Here is my code
ESP32 position motion control example with encoder
// Motor instance
BLDCDriver3PWM driver = BLDCDriver3PWM(25, 26, 27, 7);
// encoder instance
Encoder encoder = Encoder(4, 2, 1024);
// channel A and B callbacks
encoder.init();
motor.linkSensor(&encoder);
// aligning voltage [V]
motor.controller = ControlType::velocity;
// contoller configuration
motor.PID_velocity.P = 0.2;
motor.PID_velocity.I = 20;
motor.voltage_limit = 6;
motor.LPF_velocity.Tf = 0.01;
// angle P controller
motor.P_angle.P = 20;
motor.velocity_limit = 4;
Serial.println(“Motor ready.”);
Serial.println(“Set the target angle using serial terminal:”);
// angle set point variable
float target_angle = 0;
// Arduino UNO loop ~1kHz
// Bluepill loop ~10kHz
motor.move(target_angle);
// motor.monitor();
serialReceiveUserCommand();
static String received_chars;
while (Serial.available()) {
// get the new byte:
received_chars += inChar;
// end of user input
if (inChar == '\n') {
// change the motor target
target_angle = received_chars.toFloat();
Serial.print("Target angle: ");
Serial.println(target_angle);
// reset the command buffer
received_chars = "";
