Can't init current sense
I’m having difficulty getting current sense to init on my config
Driver: SimpleFOCShield v2.0.4
MCU: ESP32-S3-DevKit C N8R2
BLDC: [5010 260KV] - 12N14P (7 pole pair)(Rctimer 5010 260KV Multirotor Brushless Motor(4.0mm shaft)) running at 12V (supports 4-6s / 14.8->22.2V)
Sensor: AS5600
Application: I’m building a zoetrope very similar to this
Pre-simplefoc:
I’m running a low-impedance BLDC with a max of 750rpm / 78rad/s with a ~400g load. I never see > 800ma and I have a heatsink+fan on the L6234. So far it works great.
I’m trying to get inline current sensing working but am encountering problems.
  1. “Err too low current, rise voltage!” current sense errors
  2. higher voltage_sensor_align values cause pole pair check to fail
Starting out with:
results in:
  1. CS: Err too low current, rise voltage!
  2. MOT: PP check: OK!
MOT: Monitor enabled!
MOT: Init
MOT: Enable driver.
[  2012][E][esp32-hal-adc.c:172] __analogChannelConfig(): Pin is not configured as analog channel
[  2021][E][esp32-hal-adc.c:172] __analogChannelConfig(): Pin is not configured as analog channel
Current sense init success!
PWM frequency: -12345
MOT: Align sensor.
MOT: sensor_direction==CW
MOT: PP check: OK!
MOT: Zero elec. angle: 5.20
MOT: Align current sense.
MOT: Align error!
MOT: Init FOC failed.
the code says to bump it up. I tested with 1-9V)
motor.voltage_sensor_align = 9;
doesn’t help. It throws the same error. setting:
motor.voltage_sensor_align = 12;
results in:
MOT: Init
MOT: Enable driver.
MOT: Align sensor.
MOT: PP check: fail - estimated pp: 8.06
MOT: Zero elec. angle: 5.18
MOT: Align error!
  1. the same CS error
  2. MOT: PP check: fail - estimated pp: 8.06
With motor.voltage_sensor_align = 1 I did see this once:
CS: Switch A-B
CS: Switch B-(C)NC
MOT: Success: 2
MOT: Ready.
After that, I swapped my current sense pins and never saw it again. I also tried swapping them back to their original assignments but never saw success again.
I’ve also seen the following after swapping around 2 of the phases between the driver and motor (but returned to the other CS error on subsequent runs):
MOT: PP check: OK!
MOT: Zero elec. angle: 5.16
CS: Err align B
MOT: Align error!
I looked at the code but didn’t see any hints.
To be clear I almost always get the CS: Err too low current, rise voltage! error.
Full code here:
#include <Wire.h>
#define I2C_SDA 4 // SDA on encoder (encoder yellow)
#define I2C_SCL 5 // SCL on encoder (encoder orange)
#define CURRENT_SENSE_B 6  // GPIO6 - ADC1_5
#define CURRENT_SENSE_A 7  // GPIO7 - ADC1_6
#define PWM_A 15 // 9 on simplefoc shield v2 (red)
#define PWM_B 16  // 5 on simplefoc shield v2 (orange)
#define PWM_C 17 // 6 on simplefoc shield v2 (yellow)
#define ENABLE 18 // 8 on simplefoc shield v2 (green)
BLDCDriver3PWM driver = BLDCDriver3PWM(PWM_A, PWM_B, PWM_C, ENABLE);
// Try different constructor variations with explicit float types
// Version 1: Using defines with float literals
InlineCurrentSense current_sense = InlineCurrentSense(0.01f, 50.0f, CURRENT_SENSE_A, CURRENT_SENSE_B);
float target_velocity = 0.0f;
void doTarget(char* cmd) {
  command.scalar(&target_velocity, cmd);
  // Serial.print("Target velocity set to: ");
  // Serial.println(target_velocity);
  Serial.println("Starting...");
  // Add debug prints for pin values
  Serial.print("Define values - A: ");
  Serial.print(CURRENT_SENSE_A);
  Serial.print(", B: ");
  Serial.println(CURRENT_SENSE_B);
  // Print the actual pin values from current_sense object
  Serial.print("Current sense pins from object: ");
  Serial.print(current_sense.pinA);
  Serial.print(", ");
  Serial.println(current_sense.pinB);
  Wire.begin(I2C_SDA, I2C_SCL);
  Wire.setClock(400000);
  sensor.init(&Wire);
  if(!driver.init()){
    return;
  motor.PID_velocity.P = 0.04f;
  motor.PID_velocity.I = 0.7f;
  motor.PID_velocity.D = 0.0f;
  motor.voltage_limit = 12;   // [V]
  motor.velocity_limit = 1000; // [rad/s]
  motor.voltage_sensor_align = 3; // [V]
  if(!motor.init()){
    return;
  if (current_sense.init())  Serial.println("Current sense init success!");
  else{
    Serial.println("Current sense init failed!");
    return;
  // driver.pwm_frequency = 20000;
  Serial.print("PWM frequency: ");
  Serial.println(driver.pwm_frequency);
  command.add('M', doMotor,"my motor");
  //  motor.monitor();
  motor.move(target_velocity);  // use the target velocity here
// columtarget, voltage.q, velocity, angle
PlatformIO config:
[env:esp32-s3_i2c_simplefoc]
build_src_filter = +<esp32-s3_i2c_simplefoc.cpp>
platform = espressif32
board = esp32-s3-devkitc-1
framework = arduino
board_build.mcu = esp32s3
board_build.f_cpu = 240000000L
board_build.partitions = default_8MB.csv
board_build.arduino.memory_type = qio_qspi
build_flags =
    -DARDUINO_USB_MODE=1
    -DARDUINO_USB_CDC_ON_BOOT=1
    -DBOARD_HAS_PSRAM
upload_protocol = esptool
monitor_speed = 115200
lib_deps =
	askuric/Simple FOC@^2.3.4
	Wire
I’m also experiencing the same issue with an ESP32s3
ESP32 working through SimpleFOCDocs, Voltage control wfm, ie motor is initialised (moved slightly) then rotates. however after I added current sense lines, motor is no longer initialised,
As above, I tried raising voltage from 2v up to 9v.
This motor is PM1105, very small and surely draws very little current at all.
getPhaseCurrents(); outputs results like these:
40.69 0.00 -9.48 79.90
12.48 0.00 6.64 42.19
24.57 0.00 -41.71 33.49
12.48 0.00 6.64 1.50
Hi @peepo , maybe you want to start your own thread for this? If not it’s also ok we can discuss it here.
Can you share some more details:
  • which driver are you using? Is it SimpleFOC shield with Hall effect current sensor?
  • what’s the phase resistance of your motor?
The phase current values you print don’t make a lot of sense, they seem very high. I think this motor would be on fire if it actually had 40A passing through it.
Hi runger,
many thanks for contributing, most of the detail I have is in the bug report #507
SimpleFOCShield v3.2, AS5048 sensor, 12.5Ω (“resistance” from manufacturer’s website)
output values are milliAmps.
I am having great difficulty understanding why voltage control now also fails in a similar fashion. ie motor initalises, ie with clear ~20 degree movement each way , but then ‘failed to notice movement’ and FOC failed/
The code, wiring etc. has not changed. (maybe I am mistaken, but…)
The reason I think it likely a bug, is the output values are large(once gain is adjusted), so the error message seems inappropriate.
Hi runger,
NB: init FOC checking sensor output, sensor output is good on its own, but not in current sense.
investigating…. now wfm, codebase looks near identical…resolved
