Hi everybody,
I’m new to the world of Arduino and I’ve been struggling quite a lot to make my BLDC motor spin.
I’m using a SimpleFOC Power Shield with an Arduino UNO with ATMEGA 328P.
I slightly modified the example code “Velocity open loop”. You can find it attached to the end of the post.
The main problem is that the motor doesn’t spin (I also tried other examples). Moreover the trying to communicate through the commander (with the Arduino IDE serial monitor) returns the message “Warn: \r detected” whenever I type a command.
I also tried with the multimeter to measure the voltage output to the motor and it seems fine.
Hope you can help me solve the problem, thank you in advance!
// BLDCDriver3PWM driver = BLDCDriver3PWM(BTN1, BTN2, BTN3, enable1, enable2, enable3);
BLDCDriver3PWM driver = BLDCDriver3PWM(9, 6, 5, 8, 7, 4);
//target variable
float target_velocity = 0;
// limiting motor movements
motor.voltage_limit = 24; // [V]
motor.velocity_limit = 5; // [rad/s] cca 50rpm
// open loop control config
// init motor hardware
I’m also a newbie here and I don’t know the SimpleFOC Power Shield
I noticed you inverted pins in your BLDCDriver3PWM constructor (phB<=>phC and enable2<=>enable3). Is it on purpose?
Hey @wilwal23
I’m a bit late to the party, but I’m glad that you’ve found the example code.
The issue might be your serial terminal settings. Make sure to only use the new line \n caracter NL.
The warning you’re getting means that the \r character as the end of string which is needs to be configured additionally if you wish to use it. If you do not need this character just change the string termination using the dropdown down in left, if I remember correctly, in the arduino serial terminal.
Thank you @Antun_Skuric !
Now the Serial monitor seems to be working fine, but the motor still doesn’t spin… There must be some alignment problem, do you know what might be the cause?
PS: I tested the hall sensors and they are working fine.
LOG FROM THE SERIAL MONITOR:
MOT: Init
MOT: Enable driver.
MOT: Align sensor.
MOT: Init FOC failed.
CODE: (basically it is the velocity example code)
// software interrupt library
#include <PciManager.h>
#include <PciListenerImp.h>
BLDCDriver3PWM driver = BLDCDriver3PWM(9, 5, 6, 8, 4 ,7);
// hall sensor instance
HallSensor sensor = HallSensor(10, 11, 12, 15);
// channel A, B and C callbacks
void doA(){sensor.handleA();}
void doB(){sensor.handleB();}
void doC(){sensor.handleC();}
PciListenerImp listenA(sensor.pinA, doA);
PciListenerImp listenB(sensor.pinB, doB);
PciListenerImp listenC(sensor.pinC, doC);
//sensor config
// software interrupts
PciManager.registerListener(&listenA);
PciManager.registerListener(&listenB);
PciManager.registerListener(&listenC);
//link sensor
// aligning voltage [V]
motor.voltage_sensor_align = 24;
motor.velocity_index_search = 1;
// contoller configuration
motor.PID_velocity.P = 0.2f;
motor.PID_velocity.I = 20;
// align sensor and start FOC
// Arduino UNO loop ~1kHz
// Bluepill loop ~10kHz
// motor.monitor();
Hey guys, @quentin you’re right, @wilwal23 please do make sure that your sensor works properly and that you can read the values from it.
Then make sure your motor works in the open loop!
So the code you’ve posted in the post before has to work, the motor has to turn when you set a certain velocity.
But please make sure to lower the voltage limit!!!
24 volt limit for the open loop will burn either your motor or your driver
Start with 1, or 2Volts.
Do you mean you successfully ran the SimpleFOC hall_sensor_example sample code?
“Unfortunately”, yes.
I attach the code below (it’s more or less the same as the one for the example).
With it, I can read as output on the serial monitor the correct angle and the correct velocity.
* Hall sensor example code
* This is a code intended to test the hall sensors connections and to demonstrate the hall sensor setup.
// monitoring port
//sensor config
sensor.update();
Serial.print("\t");
Unfortunately, the open loop example doesn’t work either…
Tomorrow I’ll try to lower the motor voltage
[The fact is that I’m powering the motor of an electric scooter with its own battery (which supplies 24V), so I guess it should run with that power more or less, right?]
