BLDC Motor Not Reaching Rated Speed?
Hi, I am using the ROB-20441 BLDC motor, TMC6300 driver, and ESP32-WROOM-32UE. There should be no compatability issues, and the motor is rated at 2000 rpm at 7.4 V. However when I run the basic example code my velocity peaks at about 50 radians per second. Anything higher and the motor freezes. Am I missing something here?
    BLDCMotor motor = BLDCMotor(7); // Motor actually has 8 poles, documentation suggests running with 7 poles
    BLDCDriver6PWM driver = BLDCDriver6PWM(33, 32, 26, 25, 14, 27); // uh, ul, vh, vl, wh, wl  ((16,17,18,23,19,33 example code))
    //target variable
    float target_velocity = 100;
    // // instantiate the commander
    // void doTarget(char* cmd) { command.scalar(&target_velocity, cmd); }
    // void doLimit(char* cmd) { command.scalar(&motor.voltage_limit, cmd); }
      driver.voltage_power_supply = 9;
      driver.voltage_limit = 9;
      driver.pwm_frequency = 20000;
      // limiting motor movements
      motor.voltage_limit = 7.4;   // [V]
      // open loop control config
      // init motor hardware
      // command.add('T', doTarget, "target velocity");
      // command.add('L', doLimit, "voltage limit");
I think that the problem is that you are using open loop control, so de driver and the mcu have no feedback about the motor, they don’t care if the motor is moving or not. Probably you are trying to accelerate the motor too fast and it can’t go from 0 to 50 rad/s (or higher) instantaneously and it starts “loosing steps”.
Try implementing some acceleration for it. (You also can do it manually increasing the speed gradually in the terminal)
Wow, you were completely correct. I put a simple loop in to increment velocity +1 until it reaches 200 and it works just fine now. Thanks!
