BLDC motor does not start by itself – works after manual push (Angle Control)
Hello everyone,
I am currently using a Nanotec DB28S01 motor in angle control mode. However, I am experiencing a very unusual behavior in my setup.
The motor does not start spinning on its own. It remains stationary even though the control is active. However, if I give the motor a slight manual push, it immediately starts spinning smoothly and continues to run perfectly without any issues.
Additionally, during the alignment process, the motor does not move at all — regardless of the alignment voltage I set.
Below is my code. I would really appreciate any suggestions or ideas on what could be causing this issue.
Thank you in advance!
float target_angle = 0; //= 6.28;
// Motor instance(pp)
BLDCMotor motor = BLDCMotor(2);
// driver instance
BLDCDriver3PWM driver = BLDCDriver3PWM(16, 4, 32);
HallSensor sensor = HallSensor(25, 26, 27, 2);
// channel A, B and C callbacks
void doA(){sensor.handleA();}
void doB(){sensor.handleB();}
void doC(){sensor.handleC();}
// initialize sensor hardware
// hardware interrupt enable
// link the motor and the sensor
// driver init
if(!driver.init()){
return;
// link driver
// aligning voltage
motor.voltage_sensor_align = 2.2f;
// contoller configuration
motor.PID_velocity.P = 0.2f;
motor.PID_velocity.I = 0.20f;
motor.voltage_limit = 12;
motor.LPF_velocity.Tf = 0.1f;
// angle P controller
motor.P_angle.P = 10;
// acceleration control using output ramp
// this variable is in rad/s^2 and sets the limit of acceleration
motor.P_angle.output_ramp = 10000;
motor.velocity_limit = 200;
// align sensor and start FOC
motor.move(target_angle);
// motor.monitor();
