I am trying to use the disco-B-G431B-ESC1 board to move my gimbal motor. I am using the simpleFOC library example. The problem I am facing is that the motor is not moving. Also, I am not getting any output on the serial terminal. The motor is vibrating at a pole. If I move the motor by force then it vibrates at the next pole but does not start to rotate. I have checked with different motors but the issue persists. I have tried this same code with other gimbal controllers (storm BGC and basecam BGC) and it works fine. The motors are not faulty as I have tested them. Could anyone please advise me what to do?
Below is the code I am using to run the motor at constant velocity in open loop mode -
BLDCDriver3PWM driver = BLDCDriver3PWM(PA8, PA9, PA10);
//target variable
float target_velocity = 10;
driver.voltage_limit = 6;
if(!driver.init()){
return;
// limiting motor movements
// open loop control config
// init motor hardware
if(!motor.init()){
return;
Below is the platform.ini file for my project -
[env:disco_b_g431b_esc1]
platform = ststm32
board = disco_b_g431b_esc1
framework = arduino
monitor_speed = 115200
monitor_port = /dev/ttyACM0
build_flags =
-D PIO_FRAMEWORK_ARDUINO_USB_HIGHSPEED_FULLMOODE
lib_deps =
https://github.com/simplefoc/Arduino-FOC.git
