B-G431B-ESC1: Beginner guide + I2C guide
Dear Richard,
thank you very much for your help - even during holiday ;-).
You lead me on the rigth way, but unfortunately next barrier for me is insight:
The build run now seems ok, but trying to upload to the ESC1 the following error appears:
Executing task in folder 20211029_ESC1_G431B_Test: C:\Users\dika.platformio\penv\Scripts\platformio.exe run --target upload <
Processing disco_b_g431b_esc1 (platform: ststm32; board: disco_b_g431b_esc1; framework: arduino)
------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------Verbose mode can be enabled via -v, --verbose option
CONFIGURATION: Redirecting...
PLATFORM: ST STM32 (14.2.0) > ST B-G431B-ESC1 Discovery
HARDWARE: STM32G431CBU6 170MHz, 32KB RAM, 128KB Flash
DEBUG: Current (stlink) On-board (stlink) External (blackmagic, cmsis-dap, jlink)
PACKAGES:
  • framework-arduinoststm32 4.20000.210603 (2.0.0)
  • framework-cmsis 2.50700.210515 (5.7.0)
  • tool-dfuutil 1.9.200310
  • tool-openocd 2.1100.211028 (11.0)
  • tool-stm32duino 1.0.2
  • toolchain-gccarmnoneeabi 1.90201.191206 (9.2.1)
    LDF: Library Dependency Finder → Library Dependency Finder (LDF) — PlatformIO latest documentation
    LDF Modes: Finder ~ chain, Compatibility ~ soft
    Found 11 compatible libraries
    Scanning dependencies…
    No dependencies
    Building in release mode
    Checking size .pio\build\disco_b_g431b_esc1\firmware.elf
    Advanced Memory Usage is available via “PlatformIO Home > Project Inspect”
    RAM: [ ] 3.8% (used 1260 bytes from 32768 bytes)
    Flash: [= ] 14.7% (used 19300 bytes from 131072 bytes)
    Configuring upload protocol…
    AVAILABLE: blackmagic, cmsis-dap, jlink, mbed, stlink
    CURRENT: upload_protocol = stlink
    Uploading .pio\build\disco_b_g431b_esc1\firmware.elf
    xPack OpenOCD x86_64 Open On-Chip Debugger 0.11.0+dev (2021-10-16-21:19)
    Licensed under GNU GPL v2
    For bug reports, read
    OpenOCD: Bug Reporting
    debug_level: 1
hla_swd
Error: open failed
in procedure ‘program’
** OpenOCD init failed **
shutdown command invoked
*** [upload] Error 1
================================================================================== [FAILED] Took 4.19 seconds ==================================================================================Der Terminalprozess “C:\Users\dika.platformio\penv\Scripts\platformio.exe ‘run’, ‘–target’, ‘upload’” wurde mit folgendem Exitcode beendet: 1.
Das Terminal wird von Aufgaben wiederverwendet, drücken Sie zum Schließen eine beliebige Taste.
I have no clue what ‘OpenOCD init’ is respectively how to solve this issue. May be you coult point me again in the right direction,
best regards to Kap Verde,
Dirk
Ammendment : What I find perplex is, that the ESC1-Device appears as a drive in my windows explorer…
Looking up in the device manager as ‘USB-Device:ST-Link Debug’.
Is this right…?
best regards
Dirk
Hmmmm… this indicates communication problems with the ST-Link. Have you installed its windows drivers?
https://www.st.com/en/development-tools/stsw-link009.html
It can also be really helpful to install the STM32CubeProgrammer - a free tool from ST Micro that can connect to ST-Links and update their firmware, etc… If STM32CubeProgrammer is finding your ST-Link and is able to connect, then the problem is somewhere in PlatformIO or its configuration. If the STM32CubeProgrammer can’t connect, there is some driver/hardware issue to resolve first.
Oh - and another thought: when uploading, there can’t be any other tools accessing the ST-Link, so things like STM32CubeProgrammer have to be closed before uploading in platformio.
Dear Richard,
thank you very much for your patience and support!
I have achieved a partial success, I made a classic beginner’s mistake and thanks to your hint discovered it: Namely, I tried to connect the board to the PC via an active USB hub (RSH-A10) - this does not seem to work in the case of board ESC1. Note on the side: With all other boards and Platformio it works however.
So, a bare raw upload without the Simple-Foc library obviously works now - success!
Unfortunately my problems with the included SimpleFOC library are now different, and even the build does not work again. Maybe you may help me again.
Here is my platformio.ini:
[env:disco_b_g431b_esc1]
platform = ststm32
board = disco_b_g431b_esc1
framework = arduino
monitor_speed = 115200
build_flags =
lib_deps = askuric/Simple FOC@^2.2
Here my code:
Here the (partial) error log after trying to upload the code to the ESC1 board:
…aso…
Compiling .pio\build\disco_b_g431b_esc1\lib544\Simple FOC\drivers\StepperDriver4PWM.cpp.o
In file included from .pio\libdeps\disco_b_g431b_esc1\Simple FOC\src\current_sense\hardware_specific\stm32g4_hal.cpp:7:
.pio\libdeps\disco_b_g431b_esc1\Simple FOC\src\current_sense\hardware_specific\stm32g4_hal.h:9:21: error: variable or field ‘MX_OPAMP1_Init’ declared void
9 | void MX_OPAMP1_Init(OPAMP_HandleTypeDef* hopamp);
.pio\libdeps\disco_b_g431b_esc1\Simple FOC\src\current_sense\hardware_specific\stm32g4_hal.h:9:21: error: ‘OPAMP_HandleTypeDef’ was not declared in this scope; did you mean ‘UART_HandleTypeDef’?
Compiling .pio\build\disco_b_g431b_esc1\lib544\Simple FOC\drivers\hardware_specific\atmega2560_mcu.cpp.o
| UART_HandleTypeDef
.pio\libdeps\disco_b_g431b_esc1\Simple FOC\src\current_sense\hardware_specific\stm32g4_hal.h:9:42: error: ‘hopamp’ was not declared in this scope
.pio\libdeps\disco_b_g431b_esc1\Simple FOC\src\current_sense\hardware_specific\stm32g4_hal.h:10:21: error: variable or field ‘MX_OPAMP2_Init’ declared void
10 | void MX_OPAMP2_Init(OPAMP_HandleTypeDef* hopamp);
.pio\libdeps\disco_b_g431b_esc1\Simple FOC\src\current_sense\hardware_specific\stm32g4_hal.h:10:21: error: ‘OPAMP_HandleTypeDef’ was not declared in this scope; did you mean ‘UART_HandleTypeDef’?
| UART_HandleTypeDef
.pio\libdeps\disco_b_g431b_esc1\Simple FOC\src\current_sense\hardware_specific\stm32g4_hal.h:10:42: error: ‘hopamp’ was not declared in this scope
.pio\libdeps\disco_b_g431b_esc1\Simple FOC\src\current_sense\hardware_specific\stm32g4_hal.h:11:21: error: variable or field ‘MX_OPAMP3_Init’ declared void
11 | void MX_OPAMP3_Init(OPAMP_HandleTypeDef* hopamp);
.pio\libdeps\disco_b_g431b_esc1\Simple FOC\src\current_sense\hardware_specific\stm32g4_hal.h:11:21: error: ‘OPAMP_HandleTypeDef’ was not declared in this scope; did you mean ‘UART_HandleTypeDef’?
| UART_HandleTypeDef
.pio\libdeps\disco_b_g431b_esc1\Simple FOC\src\current_sense\hardware_specific\stm32g4_hal.h:11:42: error: ‘hopamp’ was not declared in this scope
.pio\libdeps\disco_b_g431b_esc1\Simple FOC\src\current_sense\hardware_specific\stm32g4_hal.cpp:202:24: error: variable or field ‘HAL_OPAMP_MspInit’ declared void
202 | void HAL_OPAMP_MspInit(OPAMP_HandleTypeDef* hopamp)
.pio\libdeps\disco_b_g431b_esc1\Simple FOC\src\current_sense\hardware_specific\stm32g4_hal.cpp:202:24: error: ‘OPAMP_HandleTypeDef’ was not declared in this scope; did you mean ‘UART_HandleTypeDef’?
| UART_HandleTypeDef
.pio\libdeps\disco_b_g431b_esc1\Simple FOC\src\current_sense\hardware_specific\stm32g4_hal.cpp:202:45: error: ‘hopamp’ was not declared in this scope
.pio\libdeps\disco_b_g431b_esc1\Simple FOC\src\current_sense\hardware_specific\stm32g4_hal.cpp:277:26: error: variable or field ‘HAL_OPAMP_MspDeInit’ declared void
277 | void HAL_OPAMP_MspDeInit(OPAMP_HandleTypeDef* hopamp)
.pio\libdeps\disco_b_g431b_esc1\Simple FOC\src\current_sense\hardware_specific\stm32g4_hal.cpp:277:26: error: ‘OPAMP_HandleTypeDef’ was not declared in this scope; did you mean ‘UART_HandleTypeDef’?
| UART_HandleTypeDef
.pio\libdeps\disco_b_g431b_esc1\Simple FOC\src\current_sense\hardware_specific\stm32g4_hal.cpp:277:47: error: ‘hopamp’ was not declared in this scope
*** [.pio\build\disco_b_g431b_esc1\lib544\Simple FOC\current_sense\hardware_specific\stm32g4_hal.cpp.o] Error 1
In file included from .pio\libdeps\disco_b_g431b_esc1\Simple FOC\src\current_sense\hardware_specific\stm32g4_mcu.cpp:2:
| UART_HandleTypeDef
| UART_HandleTypeDef
| UART_HandleTypeDef
.pio\libdeps\disco_b_g431b_esc1\Simple FOC\src\current_sense\hardware_specific\stm32g4_mcu.cpp:12:8: error: ‘OPAMP_HandleTypeDef’ does not name a type; did you mean ‘UART_HandleTypeDef’?
12 | static OPAMP_HandleTypeDef hopamp1;
| UART_HandleTypeDef
.pio\libdeps\disco_b_g431b_esc1\Simple FOC\src\current_sense\hardware_specific\stm32g4_mcu.cpp:13:8: error: ‘OPAMP_HandleTypeDef’ does not name a type; did you mean ‘UART_HandleTypeDef’?
13 | static OPAMP_HandleTypeDef hopamp2;
| UART_HandleTypeDef
.pio\libdeps\disco_b_g431b_esc1\Simple FOC\src\current_sense\hardware_specific\stm32g4_mcu.cpp:14:8: error: ‘OPAMP_HandleTypeDef’ does not name a type; did you mean ‘UART_HandleTypeDef’?
14 | static OPAMP_HandleTypeDef hopamp3;
| UART_HandleTypeDef
.pio\libdeps\disco_b_g431b_esc1\Simple FOC\src\current_sense\hardware_specific\stm32g4_mcu.cpp:38:22: error: variable or field ‘_configureOPAMP’ declared void
38 | void _configureOPAMP(OPAMP_HandleTypeDef *hopamp, OPAMP_TypeDef *OPAMPx_Def){
.pio\libdeps\disco_b_g431b_esc1\Simple FOC\src\current_sense\hardware_specific\stm32g4_mcu.cpp:38:22: error: ‘OPAMP_HandleTypeDef’ was not declared in this scope; did you mean ‘UART_HandleTypeDef’?
| UART_HandleTypeDef
.pio\libdeps\disco_b_g431b_esc1\Simple FOC\src\current_sense\hardware_specific\stm32g4_mcu.cpp:38:43: error: ‘hopamp’ was not declared in this scope
38 | void _configureOPAMP(OPAMP_HandleTypeDef *hopamp, OPAMP_TypeDef OPAMPx_Def){
.pio\libdeps\disco_b_g431b_esc1\Simple FOC\src\current_sense\hardware_specific\stm32g4_mcu.cpp:38:65: error: expected primary-expression before '
’ token
.pio\libdeps\disco_b_g431b_esc1\Simple FOC\src\current_sense\hardware_specific\stm32g4_mcu.cpp:38:66: error: ‘OPAMPx_Def’ was not declared in this scope; did you mean ‘OPAMP_TypeDef’?
| OPAMP_TypeDef
.pio\libdeps\disco_b_g431b_esc1\Simple FOC\src\current_sense\hardware_specific\stm32g4_mcu.cpp:54:23: error: variable or field ‘_configureOPAMPs’ declared void
54 | void _configureOPAMPs(OPAMP_HandleTypeDef *OPAMPA, OPAMP_HandleTypeDef *OPAMPB, OPAMP_HandleTypeDef *OPAMPC){
.pio\libdeps\disco_b_g431b_esc1\Simple FOC\src\current_sense\hardware_specific\stm32g4_mcu.cpp:54:23: error: ‘OPAMP_HandleTypeDef’ was not declared in this scope; did you mean ‘UART_HandleTypeDef’?
| UART_HandleTypeDef
.pio\libdeps\disco_b_g431b_esc1\Simple FOC\src\current_sense\hardware_specific\stm32g4_mcu.cpp:54:44: error: ‘OPAMPA’ was not declared in this scope; did you mean ‘OPAMP’?
| OPAMP
.pio\libdeps\disco_b_g431b_esc1\Simple FOC\src\current_sense\hardware_specific\stm32g4_mcu.cpp:54:52: error: ‘OPAMP_HandleTypeDef’ was not declared in this scope; did you mean ‘UART_HandleTypeDef’?
| UART_HandleTypeDef
.pio\libdeps\disco_b_g431b_esc1\Simple FOC\src\current_sense\hardware_specific\stm32g4_mcu.cpp:54:73: error: ‘OPAMPB’ was not declared in this scope; did you mean ‘OPAMP’?
| OPAMP
.pio\libdeps\disco_b_g431b_esc1\Simple FOC\src\current_sense\hardware_specific\stm32g4_mcu.cpp:54:81: error: ‘OPAMP_HandleTypeDef’ was not declared in this scope; did you mean ‘UART_HandleTypeDef’?
| UART_HandleTypeDef
.pio\libdeps\disco_b_g431b_esc1\Simple FOC\src\current_sense\hardware_specific\stm32g4_mcu.cpp:54:102: error: ‘OPAMPC’ was not declared in this scope; did you mean ‘OPAMP’?
| OPAMP
.pio\libdeps\disco_b_g431b_esc1\Simple FOC\src\current_sense\hardware_specific\stm32g4_mcu.cpp: In function ‘void _configureADCInline(int, int, int)’:
.pio\libdeps\disco_b_g431b_esc1\Simple FOC\src\current_sense\hardware_specific\stm32g4_mcu.cpp:83:21: error: ‘hopamp1’ was not declared in this scope
83 | _configureOPAMPs(&hopamp1, &hopamp3, &hopamp2);
.pio\libdeps\disco_b_g431b_esc1\Simple FOC\src\current_sense\hardware_specific\stm32g4_mcu.cpp:83:31: error: ‘hopamp3’ was not declared in this scope
.pio\libdeps\disco_b_g431b_esc1\Simple FOC\src\current_sense\hardware_specific\stm32g4_mcu.cpp:83:41: error: ‘hopamp2’ was not declared in this scope
.pio\libdeps\disco_b_g431b_esc1\Simple FOC\src\current_sense\hardware_specific\stm32g4_mcu.cpp:83:3: error: ‘_configureOPAMPs’ was not declared in this scope
.pio\libdeps\disco_b_g431b_esc1\Simple FOC\src\current_sense\hardware_specific\stm32g4_mcu.cpp:99:3: error: ‘HAL_OPAMP_Start’ was not declared in this scope; did you mean ‘HAL_PCD_Start’?
99 | HAL_OPAMP_Start(&hopamp1);
| HAL_PCD_Start
*** [.pio\build\disco_b_g431b_esc1\lib544\Simple FOC\current_sense\hardware_specific\stm32g4_mcu.cpp.o] Error 1
================================================================================= [FAILED] Took 16.06 seconds =================================================================================
Der Terminalprozess “C:\Users\dika.platformio\penv\Scripts\platformio.exe ‘run’” wurde mit folgendem Exitcode beendet: 1.
Unfortunately, digging into the potential root cause of these errors is by far miles away from my coding skills.
Again, thank you very much for your patience,
best regards,
Dirk
Hey Dirk,
Really not sure what is going there… I am looking into it.
I have duplicated your project setup here on my Mac, and can confirm that I get the same compilation issues.
It seems you have found a bug in the current sensing code. I’m currently not sure if it only happens in platformio, or generally for people using the STM32G4xx MCUs.
I am opening an issue in our GitHub. I’ve already made a fix.
To get around the issue, I’m afraid you either have to wait for the next SimpleFOC library release, or use the source code version of the library. I shall post some instructions how to do this in a moment, after I have uploaded my fix.
Dear Dirk,
I have merged the fix into the dev branch of the SimpleFOC library. You will either have to wait for the next release of the library, and then update your dependency, but I am not sure when the next release will be.
Or you can continue by using the source code version of the library from GitHub.
If you’ve used git before, this should not be difficult - if you’re new to git, it might be a bit of learning experience.
You will have to “clone” the simplefoc library to your local PC, and switch to the “dev” branch. Using the git command line tools for windows, you would do the following inside the “lib” folder of your project.
git clone https://github.com/simplefoc/Arduino-FOC.git
cd Arduino-FOC
git checkout dev
which will create a folder Arduino-FOC, and switch it to the dev branch. Since it is in your project’s lib folder, it will be used as a library.
Then, in platformio you would remove this line (the library dependency):
from the platformio.ini file, and do a “Clean” and “Build” and things should work.
One more thing:
Please also add the line
lib_archive = false
to your platformio.ini file. It is an option required for platformio, stm32 and simplefoc.
I always appreciate to learn ;-).
First, thank you for your patience and assistance. I’m glad that I could contribute unexpected to the library.
So i try to follow your instructions, and switched to the ‘dev’ branch:
Currently I’m not really sure, what I’ve done (even if you explained very well), but I can’t see any mistakes so far.
Then I modified as advised my platformio.ini to:
platform = ststm32
framework = arduino
build_flags =
lib_archive = false
I pressed the bin-Button (PlatformIO:Clean) and tried a PlatformIO:Build after.
Unfortunately still same errors as reported :crazy_face:
It’s not urgent for me, and I’m really glad to go ahead with the SimpleFOCShield and have good results and success there. :v:
So I’ll wait for the next release of the library and will give the ESC1 board then a second chance.
Enjoy your holiday!
Best regards,
Dirk
I recently updated platformio and ststm32 versions and I’m having similar compilation issues.
Compiling with -D PIO_FRAMEWORK_ARDUINO_USB_HIGHSPEED_FULLMODE no longer works, this results in the compilation error "This board does not support USB High Speed! Select 'Full Speed' in the 'Tools->USB interface' menu" Removing this define fixes the compilation. I wasn’t able to find the cause of this breakage, the specific code that throws this error has been unchanged since 2018.
Uploading the binary also ceased working. This was fixed by installing the st-link driver (STSW-LINK009). Before updating platformio/ststm32 everything worked without the driver.
Now I have some issues with serial. printf() works and spits out data at a baud rate of 9600. getchar() does not work, neither does Serial.printf(). Serial.begin(115200) also has no effect. Serial.flush() finishes in constant time, regardless of the amount of bytes placed into the send buffer. Serial.begin() takes exactly 10 milliseconds to finish, it might hit a timeout somewhere…
Can someone with a working setup copy/paste the first 20 lines of their compile output so I can see exactly which package versions are used?
Edit: I was able to upload a sketch with arduino IDE that has functional serial, with the latest package versions (framework-arduinoststm32 2.1).
Edit: I found the problem. Compiling with the flag PIO_FRAMEWORK_ARDUINO_ENABLE_CDC. silently breaks the serial terminal. Do not use this flag.
Hi, I had similar problem as you with the `-D
IO_FRAMEWORK_ARDUINO_USB_HIGHSPEED_FULLMODE which I removed. The Serial.println() etc was solved by #define Serial Serial2 and keeping the PIO_FRAMEWORK_ARDUINO_ENABLE_CDC.
Have you noticed any problem with the channel 2 PWM output? Se my thread https://community.simplefoc.com/t/b-g431b-esc1-is-missing-one-pwm-output-signal/1405
Regards
Anders
I did not notice any problems with the pwm output, motor/current control was working as expected.
This is my config:
platform = ststm32
framework = arduino
lib_archive = false
build_flags =
    -D HAL_OPAMP_MODULE_ENABLED
    -D HAL_TIM_MODULE_ENABLED
lib_deps = path to local simplefoc checkout
I’m using the latest release version (as of yesterday) of platformio, arduino, stm32. And the latest dev of simpleFOC.
Hi everyone,
I’ve been trying to get a sensorless BLDC motor running with the B-G431B-ESC1 and have run into some issues. For reference, I’m following @Valentine’s code (Apr 19) to control the motor via the inbuilt potentiometer and have set up the environment according to @ultra.robotics’s Arduino IDE guide (Mar 12).
The issue seems to be with the Opamps. I’m not connecting any sensors to the ESC for now. Here is the script of the errors:
In file included from C:\Users\kevin\Documents\Arduino\libraries\Simple_FOC\src\current_sense\hardware_specific\stm32g4_mcu.cpp:2:
C:\Users\kevin\Documents\Arduino\libraries\Simple_FOC\src\current_sense\hardware_specific\stm32g4_hal.h:9:21: error: variable or field ‘MX_OPAMP1_Init’ declared void
In file included from C:\Users\kevin\Documents\Arduino\libraries\Simple_FOC\src\current_sense\hardware_specific\stm32g4_hal.cpp:7:
C:\Users\kevin\Documents\Arduino\libraries\Simple_FOC\src\current_sense\hardware_specific\stm32g4_hal.h:9:21: error: ‘OPAMP_HandleTypeDef’ was not declared in this scope; did you mean ‘UART_HandleTypeDef’?
| UART_HandleTypeDef
C:\Users\kevin\Documents\Arduino\libraries\Simple_FOC\src\current_sense\hardware_specific\stm32g4_hal.h:9:42: error: ‘hopamp’ was not declared in this scope
C:\Users\kevin\Documents\Arduino\libraries\Simple_FOC\src\current_sense\hardware_specific\stm32g4_hal.h:10:21: error: variable or field ‘MX_OPAMP2_Init’ declared void
| UART_HandleTypeDef
C:\Users\kevin\Documents\Arduino\libraries\Simple_FOC\src\current_sense\hardware_specific\stm32g4_hal.h:10:21: error: ‘OPAMP_HandleTypeDef’ was not declared in this scope; did you mean ‘UART_HandleTypeDef’?
| UART_HandleTypeDef
C:\Users\kevin\Documents\Arduino\libraries\Simple_FOC\src\current_sense\hardware_specific\stm32g4_hal.h:10:42: error: ‘hopamp’ was not declared in this scope
C:\Users\kevin\Documents\Arduino\libraries\Simple_FOC\src\current_sense\hardware_specific\stm32g4_hal.h:11:21: error: variable or field ‘MX_OPAMP3_Init’ declared void
| UART_HandleTypeDef
C:\Users\kevin\Documents\Arduino\libraries\Simple_FOC\src\current_sense\hardware_specific\stm32g4_hal.h:11:21: error: ‘OPAMP_HandleTypeDef’ was not declared in this scope; did you mean ‘UART_HandleTypeDef’?
| UART_HandleTypeDef
C:\Users\kevin\Documents\Arduino\libraries\Simple_FOC\src\current_sense\hardware_specific\stm32g4_hal.h:11:42: error: ‘hopamp’ was not declared in this scope
| UART_HandleTypeDef
C:\Users\kevin\Documents\Arduino\libraries\Simple_FOC\src\current_sense\hardware_specific\stm32g4_hal.cpp:202:24: error: variable or field ‘HAL_OPAMP_MspInit’ declared void
C:\Users\kevin\Documents\Arduino\libraries\Simple_FOC\src\current_sense\hardware_specific\stm32g4_mcu.cpp:12:8: error: ‘OPAMP_HandleTypeDef’ does not name a type; did you mean ‘UART_HandleTypeDef’?
| UART_HandleTypeDef
C:\Users\kevin\Documents\Arduino\libraries\Simple_FOC\src\current_sense\hardware_specific\stm32g4_hal.cpp:202:24: error: ‘OPAMP_HandleTypeDef’ was not declared in this scope; did you mean ‘UART_HandleTypeDef’?
| UART_HandleTypeDef
C:\Users\kevin\Documents\Arduino\libraries\Simple_FOC\src\current_sense\hardware_specific\stm32g4_hal.cpp:202:45: error: ‘hopamp’ was not declared in this scope
C:\Users\kevin\Documents\Arduino\libraries\Simple_FOC\src\current_sense\hardware_specific\stm32g4_hal.cpp:277:26: error: variable or field ‘HAL_OPAMP_MspDeInit’ declared void
C:\Users\kevin\Documents\Arduino\libraries\Simple_FOC\src\current_sense\hardware_specific\stm32g4_mcu.cpp:13:8: error: ‘OPAMP_HandleTypeDef’ does not name a type; did you mean ‘UART_HandleTypeDef’?
| UART_HandleTypeDef
C:\Users\kevin\Documents\Arduino\libraries\Simple_FOC\src\current_sense\hardware_specific\stm32g4_hal.cpp:277:26: error: ‘OPAMP_HandleTypeDef’ was not declared in this scope; did you mean ‘UART_HandleTypeDef’?
| UART_HandleTypeDef
C:\Users\kevin\Documents\Arduino\libraries\Simple_FOC\src\current_sense\hardware_specific\stm32g4_hal.cpp:277:47: error: ‘hopamp’ was not declared in this scope
C:\Users\kevin\Documents\Arduino\libraries\Simple_FOC\src\current_sense\hardware_specific\stm32g4_mcu.cpp:14:8: error: ‘OPAMP_HandleTypeDef’ does not name a type; did you mean ‘UART_HandleTypeDef’?
| UART_HandleTypeDef
C:\Users\kevin\Documents\Arduino\libraries\Simple_FOC\src\current_sense\hardware_specific\stm32g4_mcu.cpp:42:22: error: variable or field ‘_configureOPAMP’ declared void
42 | void _configureOPAMP(OPAMP_HandleTypeDef *hopamp, OPAMP_TypeDef *OPAMPx_Def){
C:\Users\kevin\Documents\Arduino\libraries\Simple_FOC\src\current_sense\hardware_specific\stm32g4_mcu.cpp:42:22: error: ‘OPAMP_HandleTypeDef’ was not declared in this scope; did you mean ‘UART_HandleTypeDef’?
| UART_HandleTypeDef
C:\Users\kevin\Documents\Arduino\libraries\Simple_FOC\src\current_sense\hardware_specific\stm32g4_mcu.cpp:42:43: error: ‘hopamp’ was not declared in this scope
42 | void _configureOPAMP(OPAMP_HandleTypeDef *hopamp, OPAMP_TypeDef OPAMPx_Def){
C:\Users\kevin\Documents\Arduino\libraries\Simple_FOC\src\current_sense\hardware_specific\stm32g4_mcu.cpp:42:65: error: expected primary-expression before '
’ token
C:\Users\kevin\Documents\Arduino\libraries\Simple_FOC\src\current_sense\hardware_specific\stm32g4_mcu.cpp:42:66: error: ‘OPAMPx_Def’ was not declared in this scope; did you mean ‘OPAMP_TypeDef’?
| OPAMP_TypeDef
C:\Users\kevin\Documents\Arduino\libraries\Simple_FOC\src\current_sense\hardware_specific\stm32g4_mcu.cpp:58:23: error: variable or field ‘_configureOPAMPs’ declared void
58 | void _configureOPAMPs(OPAMP_HandleTypeDef *OPAMPA, OPAMP_HandleTypeDef *OPAMPB, OPAMP_HandleTypeDef *OPAMPC){
C:\Users\kevin\Documents\Arduino\libraries\Simple_FOC\src\current_sense\hardware_specific\stm32g4_mcu.cpp:58:23: error: ‘OPAMP_HandleTypeDef’ was not declared in this scope; did you mean ‘UART_HandleTypeDef’?
| UART_HandleTypeDef
C:\Users\kevin\Documents\Arduino\libraries\Simple_FOC\src\current_sense\hardware_specific\stm32g4_mcu.cpp:58:44: error: ‘OPAMPA’ was not declared in this scope; did you mean ‘OPAMP’?
| OPAMP
C:\Users\kevin\Documents\Arduino\libraries\Simple_FOC\src\current_sense\hardware_specific\stm32g4_mcu.cpp:58:52: error: ‘OPAMP_HandleTypeDef’ was not declared in this scope; did you mean ‘UART_HandleTypeDef’?
| UART_HandleTypeDef
C:\Users\kevin\Documents\Arduino\libraries\Simple_FOC\src\current_sense\hardware_specific\stm32g4_mcu.cpp:58:73: error: ‘OPAMPB’ was not declared in this scope; did you mean ‘OPAMP’?
| OPAMP
C:\Users\kevin\Documents\Arduino\libraries\Simple_FOC\src\current_sense\hardware_specific\stm32g4_mcu.cpp:58:81: error: ‘OPAMP_HandleTypeDef’ was not declared in this scope; did you mean ‘UART_HandleTypeDef’?
| UART_HandleTypeDef
C:\Users\kevin\Documents\Arduino\libraries\Simple_FOC\src\current_sense\hardware_specific\stm32g4_mcu.cpp:58:102: error: ‘OPAMPC’ was not declared in this scope; did you mean ‘OPAMP’?
| OPAMP
C:\Users\kevin\Documents\Arduino\libraries\Simple_FOC\src\current_sense\hardware_specific\stm32g4_mcu.cpp: In function ‘void _configureADCInline(int, int, int)’:
C:\Users\kevin\Documents\Arduino\libraries\Simple_FOC\src\current_sense\hardware_specific\stm32g4_mcu.cpp:87:21: error: ‘hopamp1’ was not declared in this scope
87 | _configureOPAMPs(&hopamp1, &hopamp3, &hopamp2);
C:\Users\kevin\Documents\Arduino\libraries\Simple_FOC\src\current_sense\hardware_specific\stm32g4_mcu.cpp:87:31: error: ‘hopamp3’ was not declared in this scope
C:\Users\kevin\Documents\Arduino\libraries\Simple_FOC\src\current_sense\hardware_specific\stm32g4_mcu.cpp:87:41: error: ‘hopamp2’ was not declared in this scope
C:\Users\kevin\Documents\Arduino\libraries\Simple_FOC\src\current_sense\hardware_specific\stm32g4_mcu.cpp:87:3: error: ‘_configureOPAMPs’ was not declared in this scope
C:\Users\kevin\Documents\Arduino\libraries\Simple_FOC\src\current_sense\hardware_specific\stm32g4_mcu.cpp:103:2: error: ‘HAL_OPAMP_Start’ was not declared in this scope; did you mean ‘HAL_DAC_Start’?
103 | HAL_OPAMP_Start(&hopamp1);
| HAL_DAC_Start
exit status 1
Error compiling for board Discovery.
Thanks everyone, and apologies for any inconvenience caused.
Hi @Kevin_George ,
Which version of the STM32 platform are you running? There have been several updates recently…
At one point at least setting this build option helped things:
but not 100% sure where this goes in Arduino IDE, maybe in platform.local.txt ?
I have tried so many things to fix the same problem, but this fixed it. How did you figure out that this line was the problem and where do you get these commands from?
Welcome @Thijs_Lenssen !
I’m really glad it helped! :slight_smile:
I can’t say there is one source - sometimes one finds things in other forum posts out there in the internet, sometimes (rarely :wink: ) there’s actually some documentation somewhere, and often its just by reading the framework code. In this case, if you follow the code you’ll find the functions and definitions needed are masked out unless that define is set.
Finding the framework code is much easier in environments like PlatformIO, where you can click on functions and jump to their definitions, than in ArduinoIDE, which hides all this code from you to keep things simple.
Cool I am going to try and find it myself, thanks a lot!
Edit: I think I found it, but how is it possible that other header files are included while you didn’t define it? For example, the i2c header.
Edit2: I have a new fix by adding the following lines to the stm32g4xx_hal_conf.h file:
#if !defined(HAL_OPAMP_MODULE_DISABLED)
  #define HAL_OPAMP_MODULE_ENABLED
#else
  #undef HAL_OPAMP_MODULE_ENABLED
#endif
Ah, that is because these defines can come from many places…
one is your platformio.ini build_flags section, but other places include:
  • the board definition file, which may activate some options as appropriate for the board
  • the framework header files (so in the code itself) which may set some defaults for the board or MCU
  • the Arduino scripts that put everything together
  • and probably many more other places
So in this case someone decided, probably correctly, that very many users need I2C, and very many other libraries depend on it, and so this option was activated by default somewhere. And for the op-amp, they decided that hardly anyone is using it, and so it is disabled by default (to save program space and speed up compile times).
It all makes sense, it would just be great if it were better documented somewhere…
Well they have made the following comments in the configuration file(stm32g4xx_hal_conf.h), but it’s quite hard to find:
 * Optional HAL modules, can be enabled/disabled using
 * variant.h, build_opt.h or hal_conf_extra.h
Hi there,
I have run into the next barrier when uploading regarding OpenOCD and it is kind of similar to the one that dirk also had. Mine gives a success message instead of failed, but nothing seems to happen on the serial monitor after the uploading is finished. I have tried all my USB ports, but no success.
Verbose mode can be enabled via `-v, --verbose` option
CONFIGURATION: https://docs.platformio.org/page/boards/ststm32/disco_b_g431b_esc1.html
PLATFORM: ST STM32 (15.1.0) > ST B-G431B-ESC1 Discovery
PACKAGES:
 - framework-arduinoststm32 4.20100.211028 (2.1.0)
 - framework-cmsis 2.50700.210515 (5.7.0)
 - tool-dfuutil 1.9.200310
 - tool-openocd 2.1100.211028 (11.0)
 - tool-stm32duino 1.0.2
 - toolchain-gccarmnoneeabi 1.90201.191206 (9.2.1)
LDF: Library Dependency Finder -> https://bit.ly/configure-pio-ldf
Found 12 compatible libraries
Scanning dependencies...
Dependency Graph
|-- <Simple FOC> 2.2.0+sha.ed90016
|   |-- <Wire> 1.0
|   |-- <SPI> 1.0
|-- <SPI> 1.0
|-- <Wire> 1.0
Advanced Memory Usage is available via "PlatformIO Home > Project Inspect"
RAM:   [==        ]  16.4% (used 5372 bytes from 32768 bytes)
Flash: [=====     ]  52.2% (used 68480 bytes from 131072 bytes)
Configuring upload protocol...
        http://openocd.org/doc/doxygen/bugs.html
debug_level: 1
hla_swd
target halted due to debug-request, current mode: Thread
xPSR: 0x01000000 pc: 0x0800a35c msp: 0x20008000
** Programming Started **
Warn : Adding extra erase range, 0x08010d90 .. 0x08010fff
** Programming Finished **
** Verify Started **
** Verified OK **
** Resetting Target **
========================================================================================= [SUCCESS] Took 6.88 seconds
This is my platformio.ini file:
platform = ststm32
framework = arduino
build_flags =
lib_deps=
    SPI
    Wire
lib_archive = false
and my device manager:
Edit: I have no troubles uploading through arduino IDE
Hey, do you know which UART is connected to the ST-Link? Often it is UART2, in which case a
build_flags =
  -D SERIAL_UART_INSTANCE=2
would maybe help.
